Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
squeak problem
Old Apr 26, 2007 | 08:57 AM
D4nnyD's Avatar
Question squeak problem
hi
i have a 2003 OZ rally. the problem is everytime i go over a bump or in a hole or nething like that, i hear a squeak coming from the back. it sounds as if its coming for both wheel wells, or sumwhere around there. the tires arent rubbing so its nothin like that, i just dont kno where the squeak is from. it doesnt sound reallllly bad, but its just there. any ideas?
Danny
Old Apr 26, 2007 | 09:18 AM
SLVROZ_03's Avatar
Probably the struts or related bushings in the control arm/sway bar...
Old Apr 26, 2007 | 09:22 AM
radicaledward's Avatar
Depending upon the weather it could also just be a normal winter squeak as well - my car went from squeaking during the winter to silent once things warmed up a bit. Check around back there for anything that seems out of the ordinary though.
Old Apr 26, 2007 | 10:30 AM
Blacksheepdj's Avatar
It's the bushings. Try spraying them with WD-40. If you're still under warranty, talk to the dealer. You can get them all replaced, but if you're not under warranty, you're paying for it.
Basically, the rubber gets old and hard. It stops cushioning and starts squeeking.
waxwozax
Jul 14, 2020 09:57 PM
va1k0s
May 31, 2016 10:36 AM
Ralli04
May 7, 2007 05:29 PM
fatalbert69
Jun 14, 2005 11:39 PM
herbal77
Apr 6, 2005 05:52 AM
