Alignment
Alignment
So after lowering my GTS, I took it for an alignment. The front wasnt too far off so Wheel Works took care of it. I was told the rear cannot be adjusted? This was also the reason why my rear tires where threading abnormally.
Is this a kit available to get my rear adjusted? If there is where can i get one.
Thanks. I will post pics later.
I know when I got my alignment after putting in the Megans with a drop of ~2 inches i had the following for the rear alignment
Right Rear: -1.6 Camber, .08 Toe
Left Rear: -1.9 Camber, .13 Toe
After thinking about this for a while, I think this what may attribute to the pulling to the left issue that everyone is having. It's not really a pulling, but rather a pushing from the rear depending on how far off the camber/toe is.
But this is were a rear camber kit is really needed. Our cars will have the natural tendency to understeer when pushed hard. You need to keep rear camber near zero to let the rear end slide and you want rear toe out to help the rear of the car rotate.
Yes, rear sway bar will definitely help the rear rotate, but the negative camber is still going to fight it. As close as the upper strut mount is to the frame rail area on a Lancer, I really couldn't see a strut bar doing much, especially since the rear is multi-link and the strut itself gets no load other than compression.
lancerarmstrong
10
Feb 13, 2011 03:11 AM
XtoEvolution
29
Sep 2, 2008 12:04 PM
audictated
21
Apr 13, 2007 09:29 PM
