Installing Brakes.. need help
Subscribe
Jun 11, 2002 | 09:30 AM
When you install pads just reverse process of taking them out. Note how backing plates were on. The chrome looking one is against the piston and goes in between the pad and piston. The pads slide over the clips. If they are tight just file them a little bit till they fit smoothly over the clips. Make sure they are positions the same as old ones were when you took them out. I know this is a bit over simplified but at least I tried!
Reply 0
Jun 14, 2002 | 06:50 AM
hella effed up discs
one more thing that is important to do when changing brake pads, is to have your rotors turned, you can just take them to a machine shop and they will take off the top layers that are all skrewed up. and you are good to go.
so you may want to tear the brakes apart again and have the rotors turned.
shamus
Reply 0
Dec 29, 2002 | 11:22 AM
so no bleeding the brakes is involved or anything? just a direct replacement of the pads is all, right? i don't want to go through all the hassle of that. seems like an easy job if it's just a direct replacement
Reply 0
Dec 29, 2002 | 11:54 AM
And remember to pump your breaks a few times to bring your break fluid up. The pedal will go all the way to the ground. DO it till its normal again.
Reply 0
Dec 29, 2002 | 11:55 AM
Oops, forgot to add that you pump breaks after they have been replaced and b4 you drive off. No need to start the car, just pump.
Reply 0
Dec 29, 2002 | 11:58 AM
Great advice, Karlen, maybe we should do a How-To Feature on brake installation. What do you think?
Reply 0
Dec 29, 2002 | 12:10 PM
wait wait..so...what? im confused
this is how i undertand things..take off old ones, put new ones on, then pump your brakes a lot. correct me if i'm wrong!
Reply 0
Dec 29, 2002 | 02:17 PM
You have forgot a small clamp to open up the caliper. Otherwise, you'll never have enough brute strength ito force the caliper open far enough to take in new pads.
get anti-sqeel gel.
Reply 0
Dec 29, 2002 | 02:19 PM
yes. the fluid needs to cyl enough pressure, so the caliper can clamp properly. Otherwise, you'll have no brake force.
Also, tighten all 4 bolts extremely tight. if not, they will work their way loose and fall off.
Reply 0
Dec 29, 2002 | 08:53 PM
Yeah that wouldn't be too good.
Reply 0
Dec 29, 2002 | 10:39 PM
That sounds good Booyah. Im just lucky enough to have a pappy who has 30 years of mechanic experience. Brakes are very important!
Reply 0
Subscribe
