Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Installed eibach pro kits but one problem......
Old Jul 22, 2002 | 04:42 AM
Mental_Atrophy's Avatar
I was using a spring compressor... so the whole face thing is unlikely.. i just cant find the tool to actually unbolt the srut - bolt bracket from the strut to realease the spring. Cuz you gotta turn a nut while a bolt is held stationary..
Old Jul 22, 2002 | 05:11 AM
david02's Avatar
i'm having the same problem and eibach said they have had problems with the upper spring mount. the mount has to have the hole in the upper mount and the hole in the bottom pedastal exactly straight up and down from each other or the spring side loads creating a rubbing noise. if you look at the upper mount you can see that its offset where the bearing sits, the hole in the mount has to face directly out so it sits flat when you turn the wheel,
hope you get it fixed
Ben.harlow
Dec 22, 2014 01:57 PM
Devo IX
Mar 21, 2012 07:21 AM
KOOLER
May 15, 2011 03:04 PM
boostedgraphite
Feb 16, 2009 07:14 AM
David Buschur
Oct 19, 2005 11:49 AM
