Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Squeeling noise.
Old Jul 21, 2013 | 10:23 PM
MCcustom's Avatar
Question Squeeling noise.
I have a grinding noise on the front right wheel. I have new brakes, Rotors, ball joints, tires all balanced and alignment. So now I am stumped on the problem I have tried taking apart my calipers all seem fine. Any other answers or ideas would be awesome thanks.
Old Jul 22, 2013 | 09:52 AM
03lances's Avatar
Check the dust shield directly behind the rotor. These can get bent easily and if you just had all that work done then there is a good chance that is your issue. Just bend it away from the rotor if its rubbing
Old Jul 22, 2013 | 11:42 AM
MCcustom's Avatar
Ill take a look at it when i get off work and i will let you know if that is the issue.
Old Jul 22, 2013 | 05:09 PM
MCcustom's Avatar
So its not that. When i push the brakes lightly it comes in bursts so thinking my pads might be worn in 1 spot but im not sure.
Old Jul 22, 2013 | 05:33 PM
eusgen's Avatar
Make sure all your brake hardware and such is in correctly
Old Jul 22, 2013 | 06:22 PM
03lances's Avatar
^^ Yup time to check your clips on the pads
Old Jul 22, 2013 | 07:36 PM
MCcustom's Avatar
Ok so all the bolts are tight in correct place but the brake clips are missing from the front left brake pads.
Old Jul 22, 2013 | 08:25 PM
03lances's Avatar
That would for sure cause you some noise
Old Jul 22, 2013 | 08:50 PM
MCcustom's Avatar
Another question wht would cause my stearing to stick in either direction i turn for example: i turn a 90 degree right turn my car wants to keep turning that direction not a lot but feels like my allignment is off and same for left turns. Car was just aligned, could it be the unit that both tie rods comnect to thats causing this?
Old Jul 26, 2013 | 07:30 PM
03lances's Avatar
If I am understanding you correctly you mean if you make a turn then let go of the wheel it doesn't want to reset on its own back straight? I would start with a complete flush of your power steering system
Old Jul 29, 2013 | 09:51 AM
MCcustom's Avatar
No it resets it just want too go left as if my allignment was bad same for right turns
Old Jul 31, 2013 | 01:43 PM
03lances's Avatar
Hrmm strange. Mine will do that slightly but only on reverse coming out of my driveway but I think that has more to do with the crappy angle of my driveway. Only suggestion I can give would be to check your power steering fuild for color and level. A well as lower ball joint and tie rod ends.
Old Jul 31, 2013 | 04:25 PM
Green_Bandit's Avatar
Arent cars supposed to slightly pull to the left just a bit to keep from hitting the curb or something like that? I just got a great alignment, green around the board, and she still pulls left a bit.
Old Jul 31, 2013 | 05:28 PM
03lances's Avatar
A car is not supposed to pull either way on a flat road. However that being said roads are not flat, they are engineered not to be flat so the water will drain to either side. If your alignment is perfect then when your is in the right lane it may ever so slightly want to pull right due to the faint angle of the road while the left hand side of the road should do the opposite. Pulling can occur from brake drag as well as alignment. Doesn't take much brake drag to lead your car one way or the other when your doing 65 down the highway
ali911
Feb 27, 2017 09:43 PM
babaz7
Dec 2, 2016 03:25 AM
va1k0s
Mitsubishi TC-SST Discussion
May 19, 2016 07:57 AM
jdogstoll23
May 9, 2016 09:34 AM
Jinu0808
31
Feb 19, 2004 07:45 PM
