Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
ok....just wondering.
Old Sep 25, 2004 | 04:22 PM
hectik's Avatar
i installed the kartboy shifter bushings.....do i leave the copper colored washer on or off??? and also those base bushing fit like sh*t.... i just left em floating and tightened them down.....seems ok.....any feedback?
Old Sep 29, 2004 | 07:57 PM
lancermarin's Avatar
I think the washers go back on for the under-hood bushings. All you're replacing is the rubber part with the urethane, and the rest of the assembly should stay the same.
As for the base bushings, did you try and rattle the shifter assembly before removing those four bolts? That thing rocked quite a bit. Even though the base bushings fit "loose", tighten bolts down around them and that assembly is SOLID.
Old Sep 30, 2004 | 01:16 AM
hectik's Avatar
thanx....good thing i did leave em in.. and as far as the base bushings....i just tightened the bushings down...they didnt even fit...they were quite larger...so i just placed em..centered them and tightened....pretty solid if you ask me...
Old Sep 30, 2004 | 03:59 PM
Blacksheepdj's Avatar
How the hell did you get them to stay in? I left my copper thingies out and my shifter is fine. To each their own, I guess.
Yeah, the base bushings fit like ****. But they do the job.
Old Sep 30, 2004 | 09:26 PM
hectik's Avatar
i pushed em together reallllllllll hard......and the copper washer went in and the pin went in fine as well.,,..
LCS
Jan 19, 2016 05:23 AM
Kracka
51
Apr 7, 2012 03:29 PM
Gdogg24
Nov 9, 2010 10:26 AM
LithiumX
Sep 19, 2007 11:38 PM
93civEJ1
Sep 12, 2004 02:48 PM
