Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Works stage 2 clutch....overkill?
Old May 25, 2005 | 07:05 PM
Supa tek's Avatar
I plan on having a decent setup(cams, high compression pistons, all bolt-ons) for n/a and was just wondering if this would be an overkill for my needs?
Old May 25, 2005 | 07:19 PM
Blacksheepdj's Avatar
Nope. You'll be good. You plan on going big with the engine, so don't be cheap with the clutch.
PS - where you getting the pistons from? RRM doesn't make them anymore, and Buschur's are barely high compression.
Old May 25, 2005 | 08:20 PM
gregivq's Avatar
^Good question. You definitely don't want to go cheap with the drivetrain. Come on, all that money for pistons, cams, labor, might as well spend it on a good clutch.
Old May 25, 2005 | 08:30 PM
Supa tek's Avatar
No labor costs...I'll be doing all the work. The pistons I got from boe when he decided to sell his. 10.5:1 , the ones fromm RRM
Old May 25, 2005 | 08:34 PM
Supa tek's Avatar
No way I want to go cheap with my car. I think my wallet made me ask this question.
Old May 25, 2005 | 08:37 PM
gregivq's Avatar
I all ready got mine in, blacksheepdj will be next!!! It's worth it bro.
Old May 25, 2005 | 08:46 PM
Supa tek's Avatar
Did you see any torque gains in these? Also, in what RPM range do you feel it kick in?
Old May 25, 2005 | 08:48 PM
gregivq's Avatar
Top end, from 4k to 6k rpm.
Old May 25, 2005 | 09:54 PM
Ah, you're the mystery piston man. Welcome to the club, #5!
Old May 25, 2005 | 10:27 PM
03RallyLancer's Avatar
you can still get them from rpw
Old May 25, 2005 | 10:43 PM
Sonantoni's Avatar
You can try to find a 97-00 Mirage 1.8 4g93 clutch and you might find more variety but the works stage 2 is what I wanted until I found the clutchmasters stage 3 which is comparable to the works 2. i think i found it cheaper plus it comes with the bearing and alignment tool.
Old May 26, 2005 | 10:26 AM
Hint - the Mirage bearing will not fit on your Lancer. So make a note of that.
Old Jun 6, 2005 | 07:06 PM
Supa tek's Avatar
I don't think RPW's pistons are forged though. I'd have to double check.
Old Jun 6, 2005 | 08:01 PM
they arent... but u dont need forged to raise the c/r unless you plan on boosting or spraying
Viet-Speed
Jan 29, 2016 11:51 PM
yourSpecialisT
13
Dec 14, 2011 10:26 AM
backroadsracer
59
Mar 10, 2011 03:42 PM
Ev0cRaZy
21
Feb 8, 2008 12:02 PM
fast03evo
26
Mar 14, 2007 06:56 PM
