Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
flywheel install question (2003 Lancer OZ)
Old May 20, 2006 | 04:12 PM
Hotshot940's Avatar
when installing the flywheel there are 3 steel stamped plates. I'm trying to figure out which ones go where. there are 2 that just have the 7 holes in them and are pretty flat, with bigger holes in the middle. and then one that is the same but the hole is smaller to line up the clutch tool. I *think* that one goes between the block and flywheel on the inside, then the other one goes on the outside of the flywheel, and the final one with the hole for the clutch alignment tool goes outside of that. BUT i'm not sure. anyone who has done it, or who knows, if you could give me a clue, that would be awesome. thanks.
Old May 20, 2006 | 04:22 PM
Hotshot940's Avatar
any idears?
Old May 20, 2006 | 10:33 PM
comatose721's Avatar
i've done it but it was a long while back and my memory is shot. you didn't make note of this when you took them off?
EDIT: i dug up a shop diagram and scanned it. that should answer your question.
mark
Attached Thumbnails flywheel install question (2003 Lancer OZ)-crank-block0001.jpg
Old May 21, 2006 | 12:19 AM
Hotshot940's Avatar
that is so clutch (no pun intended) thank you very much.
oh and i pulled the motor when i was home for christmas break from school, my dad removed the tranny when i went back to school, that's why i'm now unfamiliar on how everything came apart. Thanks a lot tho.
where did you get the shop book at to scan that from? i've been looking for a manual for this car but have come up with nothing.
Old May 21, 2006 | 12:43 AM
rhyzin's Avatar
what? everybody has one except you?
jp. get it on ebay or ask someone to send it to you.
i didn't know "clutch" was a slang word...
Old May 21, 2006 | 07:57 AM
that was a slang term used by surfers in NJ about a year ago
i got the manuals from Joe...he got them from the dealer for a couple hundred.
Old May 22, 2006 | 12:56 AM
Hotshot940's Avatar
damn, a couple hundred, i think id be better off getting the chiltons book for a mirage?
also, when lining up my clutch and using the clutch alignment tool, there is a little bit of play, meaning the clutch palte isn't completely stationary when the alignment tool is in. the plate can move a little up and down and side to side, is this alright, and how should i have it for when i install it? i'm looking to get this done tomorrow.
Old May 22, 2006 | 08:16 AM
Blacksheepdj's Avatar
If the transmission won't go back into the motor, then the clutch disk is misaligned (obviously).
Did they send the wrong alignment tool? That thing should fit snug so it lines up perfectly...
Old Jun 23, 2006 | 01:32 PM
baileysboostdoz's Avatar
does any body know what the torque numbers for the flywheel and clutch are
Old Jun 24, 2006 | 06:48 AM
***Smacks forehead***
They're in the picture above...
72 ft-lbs (plus or minus 3) is the factory spec.
newevoxguy
Mar 22, 2017 05:19 AM
Mr. Evo IX
Jul 28, 2016 09:56 AM
Mr. Evo IX
12
Jun 26, 2008 09:21 PM
wprettyboy
Nov 16, 2005 09:29 AM
Vroompsh
Mar 2, 2005 03:20 PM
