Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Clutch Q
Old Sep 1, 2007 | 08:11 PM
CosmicWhite's Avatar
Clutch Q
I recently burned the clutch on my 05 and I found someone that will give me a clutch from an 03 that they don't need. Are 03 and 05 clutchs pretty much interchangable?
Old Sep 1, 2007 | 09:33 PM
zay's Avatar
zay
Not necessarily it wont be a sure fit but you can customize but how much are you gettin it for?
Old Sep 2, 2007 | 04:32 PM
All the guy wants is a case of beer. Apparently it's in pretty imaculate condition too. Would it be better to just get one for a 2005?
Old Sep 2, 2007 | 04:37 PM
zay's Avatar
zay
yeah that would be in best interest cause when mine burned out I bought a stage 2 for 4-500 so depends on what stage of clutch you want
Old Sep 2, 2007 | 09:35 PM
Alright thanks! I guess I'll order a new one then.
Old Sep 2, 2007 | 09:44 PM
Would the FX100 Clutchmaster stage 1 kit off of ultrarev be a safe bet??
Old Sep 2, 2007 | 10:57 PM
zay's Avatar
zay
yeah but go to http://www.roadracemotorsports.com/s...products_id=33 this clutch is beautiful and grabs so fast and its a act clutch but if you want stage one then this one http://www.roadracemotorsports.com/s...products_id=35 or the clutchmaster is a good bet
Old Sep 3, 2007 | 12:35 AM
That first one looks pretty nice but a little more than I want to spend right now. If you say clutchmaster isn't bad then that's what I'll go for . I don't need anything too crazy, but an upgrade from OEM would be nice.
Old Sep 3, 2007 | 02:24 PM
zay's Avatar
zay
Clutchmaster and Act are very good brands for our car
Old Sep 3, 2007 | 04:57 PM
If I get this Clutchmaster kit will I need to get a new flywheel as well or can I run my stock one?
Old Sep 4, 2007 | 07:40 AM
Tech@SA573's Avatar
Wow...let me shed some light on the situation. First of all, the 02-06 clutches are all the same. I just check the part numbers and they match up. So you could use the 03, it's just a question of whether or not you really want to. Is it a stock clutch or aftermarket? Are you putting the clutch in yourself or paying someone?
The throwout bearing in the 05 is different from the 03. If you do decide to buy the clutch from your friend, you will need to buy a TOB still. You will need the TOB regardless, but some clutch kits include it.
As for the flywheel, you don't have to buy a new one, but your old one will probably have to be resurfaced. It depends on what kind of shape it is in. If it isn't in like new condition, you will want it resurfaced.
Hope this helps. If you have any more questions just ask.
Old Sep 4, 2007 | 10:49 AM
zay's Avatar
zay
all that will come out to the same price as the 05 why go through all that when you can go straight to the new one??? and while you are at the clutchmasters you should get the flywheel if you have the extra money or like he said you can get you resurfaced. I've already went through this situation and i got a 05 thats how I know what to do
Old Oct 2, 2007 | 05:07 PM
Oki Panoki's Avatar
If u put the clutch and pressure plate in thats 2600lbs. Is that going to make the clutch pedal alot harder to press?
Old Oct 7, 2007 | 09:51 AM
Oki Panoki's Avatar
n/m answered my own question
darrell
Mar 29, 2009 02:42 PM
evil4g63
Jun 12, 2007 08:28 PM
sleeper-s
23
Mar 15, 2007 02:54 PM
Lazeum
23
Aug 6, 2006 08:56 AM
Jeff_Jeske
Jun 5, 2005 12:20 PM
