Converting AUTO to MANUAL
I pm'ed the guy. Never got a response. going attempt this in the spring. Following this guide
http://www.mitsu-media.com/showthread.php?t=8319
start hunting linkage, pedal, actual trans, shift housing, shift stick... might look into short shifter right off the bat so you don't waste money on a stock one when you know you are going to want one later.
I need a list of parts to convert 2009 mitsubishi lancer from automatic to manual. If someone could pls help i appreciate it. And if anyone knows of a place in kissimmee or orlando that does it. With parts and labor would be better.. Thanks
Email nahirm1988@gmail.com
It's possible, if I were you and this is the route you really want to take I would look for a cheap car on Craigslist so you can swap all the parts. I mean....that's what I did except I'm also doing an engine swap with the 4G69. I got the car for $1000. Tranny and engine has 65,000 miles on it. The Donor is a 2004 Ralliart.
