2002 Mitsubishi Lancer Oz Rally - Possible Transmission Issue
06 Evo Possible Engine/Transmission Issue
When I turn the key in the ignition, my engine goes click click click, then boom boom boom booooooom booooooom, eeeeeeeEEE!, then stalls. Not sure what to do.
Looks like you live in California so you can't go to AutoZone or any other parts store and have them read the codes. You either have to go to a mechanic, buy a code scanner or find someone that has a reader.
Scantools are getting pretty cheap, picking one up may be your best bet. As far as the shuddering and CEL on and off with the throttle, what makes you think it is transmission related? A flakey MAF or TPS signal may cause similar symptoms. Update us once you pull codes.
That's right. There was some dispute against the auto parts stores and some mechanics organization. Well the organization won so the auto parts stores could not pull the codes for you. Only in California.
