Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Weird acceleration
Old Feb 16, 2013 | 09:23 AM
jzilla's Avatar
Exclamation Weird acceleration
Met up with some friends last night and had a little meet. On my way home I decided to step on the gas a bit. I was in third gear hitting 2k rpm I was giving it gas and the rpms shot up to 4k really fast and stayed at that rpm . It has done that two other times I have stepped on it, any idea what that is or if that's normal? It's an 02 oz rally
I'm a noob new at this so any input would help thanks.
Old Feb 16, 2013 | 10:18 AM
Green_Bandit's Avatar
My lancer used to do that when my input speed sensor was malfunctioning. Would drive fine then give it decent throttle then rpms would jump up and hang.
Old Feb 16, 2013 | 10:49 AM
mattu's Avatar
Mine also has little "hiccups" similar to what you speak of, and speaking of the devil, I just ordered this input/output sensor kit off of ebay for mine today: http://www.ebay.com/itm/350589201673...84.m1497.l2649
From all the advice I've read on here, it seems to be a common problem for them going bad.
EDIT: This is all assuming you have an auto trans...
Old Feb 17, 2013 | 09:23 AM
jzilla's Avatar
So I should replace that sensor? I mean my engine does have 202k on it lol
Old Feb 18, 2013 | 11:15 AM
03lances's Avatar
Do you have a manual or auto? If auto listen to these guys. If manual then your clutch is going out.
Old Feb 18, 2013 | 01:40 PM
jzilla's Avatar
It's 5sp I'm gunna have my mechanic check it out
Old Feb 18, 2013 | 01:42 PM
03lances's Avatar
Yup new clutch will be needed. Make sure to resurface your flywheel too.
Old Feb 18, 2013 | 02:30 PM
jzilla's Avatar
Ok thanks!
Any suggestions on what type of clutch to get?
jennz03
Lancer Troubleshooting
Feb 20, 2017 08:15 PM
CokeEvo
Jun 29, 2016 11:06 PM
ChipperEvo
Oct 22, 2014 12:17 PM
crewdawg130
Jul 9, 2009 07:01 PM
evilbada
17
Dec 29, 2005 09:50 AM
