Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Manual Transmission Swap
Old Jan 14, 2014 | 09:41 PM
JJ.Friske's Avatar
Does anyone know if you can swap a 03 lancer ES automatic tranny into a 5 speed? I've been looking for a 5 speed tranny for the swap but I cannot find one!
Old Jan 15, 2014 | 06:42 AM
Green_Bandit's Avatar
Yes, you can.
Old Jan 16, 2014 | 02:34 AM
JJ.Friske's Avatar
Would you just use the OZ rally 5 speed?
Old Jan 16, 2014 | 09:25 AM
Yes, you would.
Old Jan 19, 2014 | 01:14 PM
eusgen's Avatar
All 4g94 engine and transmissions(only differences are manual or auto) are the same for 02-03
Old Feb 4, 2014 | 02:29 PM
Aissirk's Avatar
ECUs are different so are the transmission mounts. Been there man
Old Feb 10, 2014 | 07:26 AM
eusgen's Avatar
Ok but a 4G94 is a 4G94, should work on either ECU, same for the transmission. I know the 04+ models have an external slave but I know I have read a thread on here where someone put a transmission with an external slave on a 02-03 model and it worked..
The transmission mounts are different? As in they wont bolt up at all? even with the mount to go with your tranny depending on the year it is (02-03 or 04-07?)
Old Feb 20, 2014 | 08:46 AM
Aissirk's Avatar
The problem is not the engine, I know the engines are the same. The problem is your transmission and ecu. A manual tranny is not gonna work with an auto ecu, because the auto ecu is gonna start to look for sensors that aren't needed in the manual tranny. The Manual ECU has a different pin configuration than the auto so you can't swap it. Unless you can reflash the auto ECU to work as a manual ECU which from my understanding you can't.... the swap is simply impossible unless you are willing change your wiring harness.
My understanding is that they're different and they're located in different places. I'm not sure about that one.
Everything I'm telling you is based on what I read on this very forum. If somebody knows more about the swap please do say cause I'm still interested in doing mine if its possible.
Old Feb 20, 2014 | 08:53 AM
Aissirk's Avatar
Check this thread out:
https://www.evolutionm.net/forums/la...to-manual.html
They're saying you can reflash the ecu. no confirmation tho.
17579EVO9MR
May 30, 2016 12:13 PM
jaime8754
Apr 29, 2016 11:34 PM
tbryant0226
Jan 13, 2014 07:51 AM
gonungeter
10
Mar 25, 2013 11:51 PM
silverguy
27
Nov 5, 2010 01:10 PM
