Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
2003 lancer oz rally transmission/clutch issues
Old May 25, 2015 | 08:59 PM
yoda1's Avatar
Ok ive looked up on the forms ive seen similar situations and issues i just recently changed the clutch.everything new clutch plate ,pressure plate,slave cylinder,clutch master cylinder .i was in the process of bleeding the slave i started to get pressure to the petal as i was bleeding the clutch i top it off the brake fluid to the top closed it with the cap .and i repeated the process about five times .i double checked all the lines for leaks no leaks ,looked under the car no puddles i started the car it got all the gears so i turned it off .when i got back in the car 3 hrs later there was absolutely no pressure to the pedal idk if i missed something please inform if i am thank you
Old May 25, 2015 | 10:17 PM
CrAnSwIcK's Avatar
how exactly did you go about bleeding?
Old May 26, 2015 | 04:41 AM
yoda1's Avatar
Its was me and my bro we bled it from the slave i sat in the car had him open the bleeder as i push on the pedal just before it hit the floor he would close it .we repeated this process till we got pressure and we also paid attention to the brake fluid level
Could the cap to the reservoir effect the bleeding processes as well .cause when we where bleeding the clutch i did hear some air escaping from it ?
Old May 26, 2015 | 04:03 PM
CrAnSwIcK's Avatar
once the system has no air, and the reservoir is full it can no longer draw air, unless the piston master cylinder has blow-by and fluid is low...what you want to do, is depress the pedal SLOWLY, and FULLY to the floor, open and close the bleeder nipple, then release the pedal, DO NOT pump the pedal, and don't let the fluid drop below MIN...try again, and if you lose pressure, you may have a defective part...
Old May 26, 2015 | 07:51 PM
yoda1's Avatar
Thank you for the advice ima get to it first thing in the morning .
ThanDaMan69
10
Mar 6, 2021 10:20 AM
Pegasus
Oct 4, 2014 10:18 PM
be12nard
Mar 11, 2005 09:15 PM
