Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Triptronic Downshift
Old Dec 18, 2017 | 10:09 PM
IGX's Avatar
IGX
New to triptronic transmissions and need some help, does the upshift and downshift happen at any rpm and speed?
Will I be able to go to 4th even at low speed or go to 1st at very high speed?
Thanks!
Old Dec 19, 2017 | 07:19 AM
zeRep85RA's Avatar
Thanks!
Tiptronic? You mean dual clutch (SST)?
No and No. Why would you want to?!?!?!??!?!
z
e
R
e
p
Old Dec 19, 2017 | 06:03 PM
IGX's Avatar
IGX
I'd like to race the car at the track and I noticed that when I'm at a certain gear, it won't downshift until I am at a specific rpm/speed. It seems consistent so I don't think there is an issue wit the transmission.
Entering/Exiting a corner at a high gear may give me a slower entry/exit speed than being at a lower gear.
Old Dec 19, 2017 | 06:13 PM
IGX's Avatar
IGX
Sorry its a conventional automatic, the non sst models
Old May 14, 2019 | 07:18 PM
GTA.RS's Avatar
If nobody has PMd you about this etc
If you have a built stregthened auto you can flash/remap the trani for race/street
You can set min ups to max ups. Max lockout downs & min downs
A built box doesn't shine unless you reflash up pres, shift time, down pres, max
solenoid duty cycle pres & convertor lockup remapping for tightening it up high
A built box with std mapping shifts like a std box. Only strength insurance
You can run a bit of inceased pres with just welded planetries
But std clutch pack style = flexing clutch packs, slip & heat
Auto mode can be very good. Tippy mode for holding gears like driving a manual
7.5k auto mode upshifts are quite good. Past that is wasting the torque in the next gear
4th to 5th you can set to say 8.5k so you can finish a drag in 4th auto mode
As far as downshift lockout revs go, you need to allow some revs to the next gear up
My lockouts settings are
2 to 1 31mph max
3 to 2 60mph
4 to 3 93mph
5 to 4 155mph
Those lockout speeds are 6k in the next gear down
Above those speeds I'm locked out of downshifting. Idiot proof
This is with GTA 3.334 final drive. Long legs
Changing to a 3.684 final drive would redline all gears quicker
I hope this makes you understand the auto workings a bit more
jnick
Jul 2, 2011 12:46 AM
TurboFour
Sep 5, 2004 11:28 AM
bpclements
41
Feb 12, 2004 03:46 PM
RalliArtGuy555
Driving Techniques
164
Nov 5, 2003 07:44 PM
