HELP: Fuel Pump Install
I'm running into a little problem installing my turbo kit. The fuel pump from RRM doesn't seem to fit in the stock housing. I got the pump into the housing, but the plastic retainer that holds the pump into the housing doesn't fit anymore because the pump is longer than stock. Any suggestions?
Problem solved. One quick call to RRM when someone was actually there (ie not at 6pm PST and not on Saturday) and I got my answer in 30 seconds. Two of the clips will suffice, but I'm going to grind mine down a bit so I can get all four to fit.
livelyjay
Lancer Aftermarket Forced Induction Tech
Oct 26, 2004 08:42 AM
