Adjustable shift light
Old Jan 28, 2006 | 12:48 AM
sykou's Avatar
Unhappy Adjustable shift light
Okay i got one of those adjustable shift lights from ebay and i hooked it up to my car. But i switched the positive and the negative so i blew one of the capaciters. Dunno if theres any one that can help me with this but i replaced the cap and hooked everything back up correctly. When i turn my ignition on i see the startup "blip" from the light but it wont go on when it reaches my shift point. I looked at everything and it doesn't seem that anything else is blown.
Could it be that i need a better ground. I checked for the voltages and they seem fine. Around 14 or so between the pos and neg. And around 3 point something from the rpm wire. Am i just plain outta luck here? Hope someone can help Thanks in advance!
Old Jan 28, 2006 | 09:08 AM
Walkingchaos's Avatar
Def sounds like you cooked something in there bro, sorry
Old Jan 28, 2006 | 11:13 AM
Blacksheepdj's Avatar
Dumb question - is it set?
Maybe the shift light is set at 6500 or something?
Never hurts to ask...
Old Jan 28, 2006 | 12:05 PM
grubiaco's Avatar
some of those shift lights require you to cut certain wires depending if the vehicle is 4, 6, or 8 cylinders. That can throw off the rpm.
If, anything you can keep on adjusting the rpm until it goes off.
Old Jan 28, 2006 | 03:03 PM
sykou's Avatar
no i set it at 3k and i made sure to cut the wires to adjust it to 4 cylinder. Awe this sucks. Well shet happens right. Thanks everyone for the help
Enjoi926
May 31, 2017 06:47 PM
Reed44
Sep 18, 2007 05:27 PM
CityKnight
May 27, 2005 03:08 PM
Nevaeh
Lancer Engine Tech
Sep 22, 2004 08:57 AM
sparcoevo
Mar 1, 2004 01:34 PM
