died left side(whole) lights! please help!
left side(whole) lights out! please help!
wasup guys! i got some problem here. i tried to change cluster bulbs but i couldn't cuz i bought wrong bulbs(i've took off 5 bulbs and put'em on again). BTW after that.... my (only) driver's side parking light, tail lights, cluster lights were out. i checked all bulbs but they are not blown. is there anyone happend like this?
what sould i do with this???? please help me!!
Check all of your fuses, make sure you reconnected everything, and give all of the connectors just a lieele extra push together for good measure. If that doesn't fix it, just follow the wiring as far as you can and make sure there is no visible damage... if that doesn't help, I'm out of ideas
The same exact thing happened to me. Its def not the bulbs. I was installing my turbo timer. One of the fuses blew under the hood in the fusebox. Dont remember which one so you may need a fuse tester to find out but I think we had the same exact problem.
hmm.. i'll check all the fuses tomorrow. i hope thats not the wiring problem if is than it's gonna be very difficult to me. any way thank you guys i appreciate it ! i'll go check all da fuses tomorrow.
i found a blown fuse at under the hood fuse box. i put a new fuse and turn the lights on but it's immediately out. then i check that fuse again...it's blew. i think the problem is wiring.
now im a too noob to get into wiring(dun even know where should i strat to look)...so
is that the best way to going dealer? or do you guys know somewhere else i can go? help me again please
AboodsEvo
Dec 9, 2010 08:58 AM
