I think i f-ed up my trans
Old Jun 20, 2006 | 10:17 PM
OZrallyMatty's Avatar
From: addison, not to be confused with aurora, illinois
I was taking my turns at like 60 - one of the times, i skidded almost totally to the side, and my engine stalled, now it seems like my tranny doesnt kick in as fast and it seems like it slips or something (it's an auto). Could be nothing or it could be sereous. Let me get some opinions.
Edited for content by Blacksheepdj
Old Jun 21, 2006 | 03:37 AM
eehjay's Avatar
Try disconnecting your battery [resetting your ECU]. It helps for some of problems. I don't know if it will help with yours, but it's worth a shot. If that doesn't work, check for any leaks/damage/disconnections/anything that isn't normal. Then let us know.
Edited for content.
Old Jun 23, 2006 | 09:34 AM
Blacksheepdj's Avatar
OK, I now deleted a half-dozen posts. STOP CALLING HIM AN IDIOT. If you can't answer his question, stay the **** out of this thread. That is the only warning you get.
Old Jun 23, 2006 | 09:52 AM
civilrage's Avatar
tranny is f'd, only thing i can think f is reset battery but that prob wont work.
and what mods do u have man? be carfull on those turns
Old Jun 23, 2006 | 10:37 AM
Wallesasuaz's Avatar
Could be your axle boots.... This happened to me when I was doing my suspension. the boot seal disconnected from the rod and it caused the transmission not to shift. It's someting electronical within the transmission... REmove the tires and move the axles to see if there's any wierd movement.
Old Jun 24, 2006 | 10:37 PM
hey i reset my system, it worked, the ecu was making it shift slow and stuff its fine now, thaks blacksheepdj for deleting that stuff, i shouldnt be treating my grocery getter like that anyway
Old Jun 24, 2006 | 11:37 PM
eehjay's Avatar
So resetting the ECU actually did work? Hmm, I wasn't even truly sure if it would. Yeah, in retrospect I shouldn't have said the things I did. So thanks blacksheepdj, we all learned a lesson.
Old Jun 25, 2006 | 03:14 PM
good work!
Old Jun 25, 2006 | 06:33 PM
airlinevomitbag's Avatar
Ok this doesn't make any sense and I'm only doing this so someone else doesn't get the wrong idea of how stuff works.
Axle boots are part of the axle assembly and axle's are related to the tranny only because they are splined at one end and fit into the tranny so the tranny can turn them. The shifting has already happened at this point. There are no electronics on the axle because it is spinning and the tranny is not. Axle boots have zip to do with the tranny. They cover the constant velocity joint on the outside and the inside ones protect a roller bearing assembly.
zasboy
Feb 28, 2016 03:46 PM
EVLX
Feb 2, 2016 06:00 AM
06evol
For Sale - Cars For Sale
13
Oct 12, 2015 01:51 PM
DynoFlash
Aug 12, 2006 10:02 PM
