HELP HELP HELP - water in engine!!
Old Oct 20, 2006 | 09:55 AM
Z_Lancer_Man's Avatar
Originally Posted by Kats
Dude if you sucked water into the air filter, it isn't your oil you have to be worry about. Okay think about it, AIR/FUEL mixture, outside air going into the cylinders to make the 14.7/1 ratio needed to fire the pistons. So by sucking water, you now have water/gas and air . Take out the spark plugs, and check there condition. Next stick a tube connected to a syphin into each spark plug hole, and see if you have any remaining water in the cylinder head. Hopefully, you didn't screw anything up. HTH
Water in your oil would mean a hole in the block. Obviously, if there isn't water in the oil, then he has lesser problems. Just a way to check.
Old Oct 21, 2006 | 07:33 AM
Kats's Avatar
Z Lancer, true, but the oil would not be clear, if mixed with antifreeze, ie...broken block, then the oil would be like vomit. He thankfully sucked a small amount of water vapors causing the stall. He was real lucky as I have seen piston damage without the block breaking in a Mits eclipse, and piston breaking putting a whole completely through the block thus losing all oil/ antifreeze in the engine. He is obviously a novice as he repeatedly try to restart the engine. Seriously, if you have experience with auto mechanics, and you were in his situation would you have tryed numerious restarts. Maybe I have been doing this too long and seen way too much. Just 16 years of owning my own shop as experience, but hey what do I know.
Old Oct 21, 2006 | 01:12 PM
superalf574's Avatar
he doesnt have hydrolock unless he drove in a 2 foot deep puddle then ya i have a cai and i live in california and it rains most of the time and my filter doesnt get wet at all hmm
Old Oct 21, 2006 | 01:37 PM
DRFTKNGG's Avatar
Water in the cylinders= bent rods...
Old Oct 23, 2006 | 04:07 AM
Foxphyre's Avatar
bent rods = cry yourself to sleep
sharkm87
Mar 29, 2010 02:23 PM
evo_soul
Lancer Engine Tech
20
Dec 15, 2009 02:01 PM
nj_08_gts
Lancer Engine Tech
Jan 4, 2008 10:15 AM
amstel78
Jun 17, 2007 12:05 AM
revhappy
32
Mar 7, 2004 09:56 PM
