stupid brakes
Old May 28, 2007 | 09:23 AM
06lanceres's Avatar
stupid brakes
first off, hello to all.
i have an 06 ES, and if going slow, like stopping in reverse or just moving ahead a few feet, as soon as i touch the brake pedal i get a clunking/ clicking noise front both front brakes (single click from each side, that is very loud) . i have replaced the pads, machined the rotors, replaced the pad shims and packed all the sliders with grease, but to no avail. has any one got this before, i tried searching but nothing. dealership can hear it but can't find it. thanks
Old May 28, 2007 | 09:28 AM
yellance's Avatar
yes its normal its your calipers adjusting
Old May 28, 2007 | 09:36 AM
06lanceres's Avatar
not that im under-minding you, but how is it that it is normal that if you are standing 15 feet from he car and you hit the brake you can hear this loud clunk
Old May 29, 2007 | 05:39 AM
06lanceres's Avatar
bump, anyone else with an idea?
Old May 29, 2007 | 09:29 AM
mauisurf2003's Avatar
like as u break there is a clunk clunk clunk or just one single clunk?
Old May 29, 2007 | 09:34 AM
opps just read you said one click per side... so something is loose cause your hearing somthing move back and forth you need to get under you car and make sure all your bolts are in and tight and that u have the correct pads in that aren't too small and moving around in your caliper. do that and update mang
Old May 29, 2007 | 10:46 AM
06lanceres's Avatar
checked all the suspension, everything solid. i checked the pads with a set at the dealership, since i work nextdoor, and they are right. im pretty much lost.
Old May 29, 2007 | 12:12 PM
Go2fast's Avatar
Check your brake fluid resevoir and make sure its full.
Old May 29, 2007 | 12:43 PM
SLVROZ_03's Avatar
Did you check to make sure the springs are seated properly? My friend and I just installed 4 new KYBs in his 240, and one spring is about an inch away from it's proper seat and makes that noise over bumps, turns, and breaking...
But then again my friend gets that on his IS300, and we have no clue what it could be! New everything and it's all tight...
Old Oct 13, 2007 | 11:21 PM
Ike's Avatar
Ike
Edit: Dumb Evo owner posts in Lancer forums, news at 11!
Old Oct 15, 2007 | 06:33 AM
02-Lancer-Es's Avatar
If u never fixed this ,i know what it is.
Its ur pad clips, this was happening to me , and got annoyed BAD
since the pad clips arent there there is a little gap and when pushing the brakes would cause the pad to move and hit the caliper.
Or it could be the caliper /or bracket thats lose
Old Oct 15, 2007 | 02:15 PM
SLVROZ_03's Avatar
Yeah, it's been a while...did you find it? or just sell the car? LOL
Kracka
22
Aug 17, 2016 09:31 AM
yoster4
Sep 19, 2010 08:02 PM
Piro Fyre
23
May 15, 2010 12:34 PM
LancerShop.com
Evo 'For Sale' Suspension / Brakes / Handling
Sep 15, 2008 02:29 PM
jimmyv65
Sep 4, 2003 03:07 PM
