instrument panel
Old Jun 11, 2007 | 09:20 AM
2fast2drv's Avatar
instrument panel
i have a 2006 lancer ES.i just recently put in a new head unit and new wiring harness made for easy conversion. When i installed it there were 2 extra wires from the harness and about 4 extra from the unit. the 2 wires from the harness are orange and say illumination and dim and are orange one with a stripe. the ones from radio are blue(2) black and brown. ive tried connecting some of them but i still get nothing. the lights from the speed rpm and other guages wont work but lights such as engine, gas work fine. im fine driving without lights but i bet cops wont be.
Old Jun 12, 2007 | 08:14 AM
jakermeister's Avatar
You might wanna move this to the audio section.
Old Jun 12, 2007 | 09:34 AM
SLVROZ_03's Avatar
Okay, so you switch in your post from the radio (HU) to the gauge cluster not lighting up. Plz explain what the cluster lighting has to do with the HU again? The "dim" wire you don't "need", and the other might be for a power-antenna (which we ain't got).
Old Jun 16, 2007 | 11:46 AM
mrblob20's Avatar
+1 ^
Illum wire you don't need either. A blue one from the deck is usally remote wire which hooks up your amps. If you don't have any amps... you don't need to hook that one up. the black is ground usually... hook that up to the chasis of your car!!!! usualy the metal bar behind the deck is good enough.
The lights in your odometer wont work now cuz you probably blew a fuse experimenting with those extra wires!
beetle_orange
Evo X How Tos / Installations
11
Jan 28, 2016 10:53 AM
Boosted_EvoVIII
Mar 12, 2012 03:19 PM
D1no
Jan 17, 2010 02:41 PM
DruMMinStUd06
Oct 27, 2006 12:05 AM
dreamevo
Sep 20, 2006 06:50 AM
