ways to prevent/cover up rust?
Old Sep 21, 2007 | 02:32 PM
IC3M4N2's Avatar
i was getting out of my lancer today, only to see that i have nickel/quarter sized rust spot where my door closes, im so angry. but is there anyway to prevent it from spreading since winter is coming up? also is there a way to cover it up and protect further rust?
Old Sep 21, 2007 | 02:40 PM
ambystom01's Avatar
Paint.
Old Sep 21, 2007 | 02:42 PM
crypto's Avatar
Former Vendor
sand the rust away a bit, then put some primer on it, then when that dries, use touch up paint with the correct color
Old Sep 21, 2007 | 03:08 PM
sykou's Avatar
you could try a rust dissolver but keep in mind that if you get it on paint it will strip it right off. I like Naval Jelly cuz its thicker so it doesn't run as much on vertical applications etc...
Old Sep 22, 2007 | 07:40 AM
slipshft's Avatar
Also make sure that (if possible) you check the other side of the sheet metal. In some cases the rust could have started on the opposite side of what you are seeing, and any attempts to fix it could be in vain. Get all that you can, or like cancer it will spread.
Old Sep 22, 2007 | 09:38 PM
IC3M4N2's Avatar
ok thanks guys, ill look into this.
lasthero32
Northeast Region
Nov 28, 2016 08:16 PM
splattj
Apr 24, 2016 08:17 AM
nuggetinu
May 22, 2015 10:07 AM
CaptainQuickie
Nov 6, 2010 08:47 AM
razo
Canadian Forum
11
Feb 21, 2008 02:09 PM
