Cracking suspension
Old Feb 6, 2008 | 09:41 AM
  #31
funkad3llic's Avatar
i havent noticed any noise from mine yet. hmm.. will defenitely keep an ear out for this just in case
Old Jun 24, 2011 | 10:13 AM
  #32
MorbidDK's Avatar
Anyone still having this problem? Did it go away? Did you find an ultimate fix for it? I've got a stock '08 ES that is doing the same thing and has been for some 40k miles or so. Generally only noticeable when backing up turning to the right, but seeing that we are nearing the end of the warranty, I was curious if it was a larger issue or not.
Thanks in advance.
Old Jul 31, 2011 | 05:08 AM
  #33
evolover221's Avatar
Mine i hear when i go in graded road and it's sucks !! like i am driving an old pick up !!
Old Aug 17, 2011 | 07:36 AM
  #34
djslik408's Avatar
on my 08 GTS the sound went away after switching to a new spring and struts.
Old Aug 17, 2011 | 09:53 AM
  #35
08Lanc3rGTS's Avatar
i don't know if it's the same problem with everyone on here but i got the same knocking sound when i turn at low speed (like coming out of a parking spot or backing out from a driveway etc) after i had my struts changed. it turns out the knocking sound was coming from the spring rotating and hitting the strut tray that is sitting on. (i think someone else on this thread had mentioned it) the mechanic was able to jack up my car and rotate the spring with his grip and i can see it was rotating and the end of the spring coil hitting the "stopper" on the tray in the strut. he says the top part is supposed to rotate with the turns but the bottom should be sitting securely on the struts.
the good thing is that it doesn't affect the drive or the components in any way except for the annoying sound when turning at low speed. the mechanic suggested to me to spot weld the bottom spring coil to the strut tray that is sitting on. i haven't done it yet but i'll keep you updated when i do.
Old Sep 6, 2011 | 07:27 AM
  #36
daniphantom's Avatar
yelp having this same problem and it didnt start till after i lowered my car, ive put it on lifts and checked if it was seated right and i cant find anything wrong with how its in there, only happends when i back up? let em know if anyone figures out anything
Old Oct 19, 2011 | 06:32 PM
  #37
grk222's Avatar
I get the same sound too. Its really loud. I dont know what its from.
Old Oct 26, 2011 | 12:11 PM
  #38
link627's Avatar
Please do. I have a VERY SIMILAR problem and want to know if there is a fix for it.
Old Nov 30, 2011 | 02:45 AM
  #39
LancerTZ's Avatar
coilover will fix the problem, stock spring i don't have it. after i upgrade hnr spring after a few week i got that noise everytime i make a turn. full turn only. both side left to right.
DaEvoPusha
May 10, 2017 01:26 PM
Drunken0elf
Oct 2, 2016 06:37 PM
nesty2
16
Jan 15, 2015 09:16 AM
Norwegian Erik
Aug 9, 2010 03:57 AM
Z-Ball
Dec 23, 2006 06:01 PM
