rough idle with intake
Old Dec 26, 2007 | 11:29 AM
jessiec132's Avatar
yea i just put on an intake on my 08 lancer and wen i start it. the car idles rough for a few seconds and wen im at low rpms the car feels like it lose power. can any1 help me or any suggestions
Old Dec 26, 2007 | 11:33 AM
nj_08_gts's Avatar
What intake do you have?
Old Dec 26, 2007 | 01:30 PM
evo_soul's Avatar
hard to say, i know with a exhaust upgrade the effects are pronounced, an intake should be slightly different at idle but not rough. Give it a day, the Mivec idle stablization should even it out. Drive it around for 50 miles or so and see what happens
Old Dec 26, 2007 | 02:21 PM
jessiec132's Avatar
the intake i put on was a custom i bought a filter, maf sensor adapter, and connecter rubber. but the plate to put on my car so the bolts arnt on so i taped it down until i found something to bolt it on and my engine light came on could that be wat made the light come on. i could put it down with the bolts but it would be at angle and reset the engine light would that work. thank u
Old Dec 26, 2007 | 02:26 PM
jessiec132's Avatar
it looks just like the rrm short ram intake btw
Old Dec 26, 2007 | 03:07 PM
CamShaft's Avatar
Wow...is english your second language cause I read it twice and was still confused. You probably have an intake that the MAF does line up right which is throwing the code and the rough idle. These things are very finaky sp? You need to have things lined up and just like factory otherwise there are all the fun things that happen with these new electronic cars these days.
If the engine light is on, you have an active code and its probably the maf.
If the light has gone out since you "bolted it down properly" I would then disconnect the batteries for a while and let the ecu reset itself. Some guys on here like blacksheep and I think evo soul know this better than me. But let it reset and relearn, drive it for 20 miles or so and see how it reacts. Good luck
Old Dec 26, 2007 | 03:53 PM
nj_08_gts's Avatar
You mentioned "custom mod", "car" and "tape" in the same sentence.
Old Feb 6, 2008 | 07:10 PM
MasterAK's Avatar
Rough idle---could be MAF sensor related.
amsevokid
Dec 17, 2010 02:19 AM
DREVO978
Sep 8, 2010 07:50 AM
Spanishevo
16
Aug 24, 2010 01:15 PM
turbodreamz21
Apr 26, 2009 12:03 AM
srv2790
Lancer Engine Tech
Mar 2, 2008 12:57 PM
