Tight Gears!?
Old Jan 26, 2008 | 02:32 PM
dbreault's Avatar
Tight Gears!?
My gears are really tight and its hard to get it to 1st and reverse sometimes does anyone know how to fix this??
Old Jan 26, 2008 | 02:36 PM
ambystom01's Avatar
Try changing the tranny fluid.
Old Jan 26, 2008 | 03:13 PM
dbreault's Avatar
yeah ive done that its fine.. i dont know what else it would be?
Old Jan 26, 2008 | 03:17 PM
max2evoix's Avatar
gotta let the car warm up
Old Jan 26, 2008 | 03:26 PM
dbreault's Avatar
There is no way to fix it?
Old Jan 26, 2008 | 04:00 PM
ambystom01's Avatar
If it only happens when the car is cold, it's normal.
Old Jan 26, 2008 | 04:48 PM
cfdfireman1's Avatar
If it won't go into gear let the clutch out a bit and try again.
Old Jan 26, 2008 | 06:13 PM
SLVROZ_03's Avatar
When it won't go into reverse, put it in first first. Then if it won't go into first, then try any other gears first. I think the cold has alot to do with it...my Civic has been acting this way when 15 degrees outside.
Old Jan 26, 2008 | 06:16 PM
Import Junky's Avatar
Do Lancers have a clutch pedal adjustment like the Evo? I know I had the same problem but it was all my gears when I got my Exedy Twin Disc. Once I adjusted it the shifts were like butter.
Old Jan 28, 2008 | 07:51 AM
LancerPride's Avatar
yes lancer has the pedal adjustment
Old Jan 28, 2008 | 08:26 AM
EvoBroMA's Avatar
if its cold that is very normal. just let it warm up, otherwise if you've changed the tranny fluid, try adjusting the clutch. worked for me.
Old Jan 28, 2008 | 11:33 AM
mcgarvey's Avatar
What tranny fluid did you use?
Ricoswave
Oct 13, 2014 07:37 PM
HDGamer
Nov 23, 2012 07:32 PM
Kidtkd73
Jun 8, 2012 05:55 AM
tsidrift1
Aug 18, 2011 07:14 PM
