Oil in Exhaust
Old Aug 1, 2003 | 12:10 PM
OZ_Rally's Avatar
Oil in Exhaust
Is anyone having a problem with an oil like substane in their tail pipe.
I have never seen this before except with cars that blow blue smoke
Old Aug 1, 2003 | 12:16 PM
HobieKopek's Avatar
Does it FEEL like oil if you were to youch it? (don't stick your finger in and burn yourself, but try to get some out). Any pics?
My exhaust spits fuel littered with carbon, but I know I'm running rich as hell. It looks oil-like. Could be something similar for you.
Old Aug 1, 2003 | 12:24 PM
OZ_Rally's Avatar
well heck hobie, I never thought of that. It is black like oil but not as slick. i will smell it and take a pic of it when I get home.
My car is almost stock,except for the ingenius intake , I run nothing else. Could it be the gas I use?
Old Aug 1, 2003 | 05:24 PM
ghostrider's Avatar
If you've got a pretty stock ride, it's definitely not an ultra rich fuel mixture you're running.
Old Aug 1, 2003 | 06:04 PM
fkrzo's Avatar
Is your ingenuis intake homade, because if you messed up the honeycomb in your MAS you could be running rich and that would definately look like oil.
Old Aug 1, 2003 | 06:23 PM
HobieKopek's Avatar
Damaging the MAF could definitely cause you to run very rich like that.
Old Aug 13, 2003 | 02:05 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
from registry
Shade tree stock (pull the clips up ,pull the front of case in towards you and push airfilter back against the mas and wedge the clips into the hole)
Well, that means he didn't even have to get close to the MAS, and the only side affect of this "intake" is maybe the filter gets dirtier quicker. So now what?
Doesn't has sometimes go through without getting burned sometimes, expecially on startup and certain RPMs. Could it be fuel?
Old Aug 13, 2003 | 02:31 PM
ghostrider's Avatar
I've stood right by my muffler before on a cold startup just to see how much worse the smell is without either cat. Even after having driven the car with only a resonator, I never got any oil-like substance.
I guess it could be unburnt fuel, but I dunno if that would be a byproduct of running premium gas. Granted some of it will go through unburnt, but enough to cause a buildup like that?
snowpro4g63
Nov 29, 2016 09:57 AM
TonyG
40
Nov 23, 2016 01:27 PM
DanielM
Aug 6, 2016 07:08 PM
Howulikemyevo
Mar 29, 2016 09:39 PM
limey
Mar 4, 2003 10:37 PM
