problem with my heater unit?
Old Mar 19, 2008 | 10:12 AM
OZR_Lancer's Avatar
i been having problems with the hvac control unit for awhile. specificly the cold/hot knob.. my freind has an 02 es and has the same issue as me . the difficulty turning the cold/hot knob to the hot position. its been giving me heavy resistance when i turn it.... i called mistsubishi el cajon they wanted ~$250-300 for a replacement hvac control unit....
for about 2 weeks now my car doesnt blow hot air anymore when the knob is in the hot position. funny thing is my defrost function works fine when i use it.. a/c is working fine aswell
Old Mar 19, 2008 | 10:14 AM
lancer2show's Avatar
theirs multiple lancers with this problem. is this problem under warranty or some kind of recall?
Old Mar 19, 2008 | 10:59 AM
OZR_Lancer's Avatar
my cars basic warrenty is out ( mileage is close to 48k ).bought the car last year feb 18 of 07'. i think that is covered under the basic but i dont have basic warrenty anymore..
if multiple lancers had the same issue why isnt this on a recall?
the only recall i know of is the ecu reflash.. i asked that when i bought the car and they said the ecu reflash was done
Old Mar 19, 2008 | 11:05 AM
ambystom01's Avatar
Recalls only apply to known safety or emissions issues. This is a known problem. Try switching the heater box located on the right side of the driver's side footwell (it's a white box) to hot manually.
Old Mar 19, 2008 | 11:11 AM
OZR_Lancer's Avatar
thx, ill try that tomorrow morning... not worth doing it now since its sunny outside
Old Mar 19, 2008 | 11:32 AM
kidneythief13's Avatar
I had the same problem in my old '03 OZ... had to pay $250 to fix it (Mitsu wanted $800). All it is are little plastic pieces & cords/wires behind the nob that resist, brake, or get tangled. I had to have the plastic pieces replaced & it took the idiots almost a whole week to receive parts & fix it. It worked fine afterwards... the only problem being the heat never got as hot as it once did... so make sure to check that.
Old Mar 22, 2008 | 08:26 AM
billylancer's Avatar
i have the same issue with one of my 's
i've remove the cable and ajust temp. manualy
until i get the parts
the cable is stuck i've tried to lube it but didn't worck
remove your cable maybe you'll be able to lube it!
Old Nov 19, 2008 | 08:12 AM
fizzjazz's Avatar
what are the part numbers that you guys ordered?
hearnoevo
Dec 2, 2015 09:12 AM
jbuhrman
Feb 3, 2014 06:45 PM
kyoo
Oct 25, 2011 07:23 AM
subrwho
Oct 5, 2008 12:59 AM
Duh Panda
25
Apr 17, 2008 06:03 PM
