The lancer doors
Old Mar 25, 2008 | 12:45 AM
gregsayss's Avatar
The lancer doors
Is it just me or is anyone else getting tired of how the front doors dont close easy. i already have to reopen it and push it harder. or just push it closed with my butt. does anyone know a way to fix this? or am i just weak?
Old Mar 25, 2008 | 04:15 AM
Eagles GTS's Avatar
Go pump some iron and grease the hinges with a little axle grease
Old Mar 25, 2008 | 07:03 AM
Hydrolikz's Avatar
You're just weak! Just playin' maybe it's a defect.
Old Mar 25, 2008 | 07:37 AM
elpoole's Avatar
I Ive had to take three doors apart to fix little rattles and other noises that I hear. I like my **** dead quiet. The doors are the cheesiest part of the Lancer. They feel like empty soda cans. Need to add some serious sound isolation to em.
Old Mar 25, 2008 | 11:23 AM
CamShaft's Avatar
try a 2007 dodge caliber, after you close the doors on that you will see how good our doors actually are :P
Old Mar 25, 2008 | 12:12 PM
gregsayss's Avatar
i work valet. i close many doors. ill try putting wd40 on the hidges
Old Mar 25, 2008 | 11:00 PM
chcougar1's Avatar
I've found it kind of annoying, but its just a slight annoyance....My Jetta doors would not close properly at times as well. I've noticed I have to give these doors a swifter push than the VW though.
Old Mar 25, 2008 | 11:08 PM
CamShaft's Avatar
its most likely the seal for keeping road noise out, the more the seal, the harder to close the door, and you just gotta live with it.
Old Mar 26, 2008 | 12:05 AM
Ironballz's Avatar
I've had a few people complement how they like the way my doors close.
Personally I find they require a little more effort than what I expected..but I think that's just due to thick seals...which isn't a bad thing.
Old Mar 26, 2008 | 08:27 AM
eg6motion's Avatar
its not the doors, its the seals like stated above. They will get easier after awhile but most brand new cars have huge seals in the doors that can take extra effort to close
Old Mar 26, 2008 | 10:39 AM
nunyas's Avatar
It's a combination of the two. The doors are very light. So, they don't have a lot of momentum to help them close when the seals hit. If you crack the sun roof (if you have one) the doors close very easily, all the time.
At any rate, if you think the doors feel "cheap" or like "tin cans" you can always, pull the panels and apply some sound deadening material to the inside of the outer door skins. It'll give the outer door skins a more solid sound and feel...
Old Mar 26, 2008 | 12:32 PM
Blacksheepdj's Avatar
It just takes some getting used to. That's all.
