How do you get Movies to play while driving?
Old Apr 23, 2008 | 07:25 AM
  #31
HDStig's Avatar
I'll append the information already available, and explain in more detail what I did to my gps antenna. This mini-coax is NOT standard size. I was using extron BNC's for mini-coax and had to hammer the sleeve out with a tweeker to make it just a little (little) bit bigger. I put a male BNC on both ends of the GPS antenna I cut. I then used 2 female bnc ends (premades that were chopped) to extend to the blank switched next to the steering wheel (also where the VCC wire is on a toggle) and used this switch (http://www.philmore-datak.com/mc/Page%20187.pdf). it shoulc be available at any local electronics store. Here in Calgary I got it at B&E Electronics.
From there I cut back the sleeve on the mini coax. groupped the ground wires together and crimped them with a butt connecter. then I soldered the center conducter to the 2 pins on the toggle and used lots of heat shrink to make it look good.
This does totally screw up your location but it bounces back after roughly 30-45 seconds. I didn't notice adverse effect on milage and speed. but the calculations in the center dial (instant milage, average trip milage and average speed) remained acurate. I assume this is because those calculations are not handled by the gps.
Anyways, I'm more than willing to help anyone get it right if I can. but I really do have to stress. If your not comfortable with this...PLEASE don't do it.
Old Apr 23, 2008 | 07:44 AM
  #32
chetman7's Avatar
it is not as easy as grounding the parking brake wire, The thing on ebay does technically disbale it but in a weird way, the only way to do this is it disable to the gps, cause theres a sensor on it that can tell when your moving.
Lombardi23
Mar 28, 2016 12:28 AM
This_Guy777
Evo X How Tos / Installations
37
Dec 6, 2009 10:34 PM
EMonz57
Feb 7, 2008 03:18 PM
OtownEvo
15
Jun 9, 2007 06:54 PM
MREVO8pinoy
Nov 5, 2005 05:12 PM
