Passenger Seatbelt Light??
Old Aug 20, 2008 | 05:06 PM
wicked white14's Avatar
All,
For the last year I might have been totally oblivious to this but; is the passenger seat belt light, next to the hazard button, always illuminated even when no one is in the seat? The air bag light shows it as off but the passenger seat belt light stays illuminated. Is everyone's light illuminated too??????
Old Aug 20, 2008 | 05:30 PM
MFO Jester's Avatar
My seat belt light goes off when no one is in the seat. Sometimes if you put something in the seat it thinks there is someone in it thought.
Old Aug 20, 2008 | 06:32 PM
Well, nothing is ever in the seat, that is what i thought too. Called the dealer and those idiots have no idea. They said as long as the air bag light is not on it is OK. Can anyone else take a look at theirs??
Old Aug 22, 2008 | 12:57 AM
CamShaft's Avatar
I had this issue...although not with my car it was with the loaner DE they gave me. I would figure its a faulty sensor. Because the seat will sense weight and deploy the airbag faster with a higher weight than with smaller weight. It will also turn the air bag off if the weight is under a certain value.
You have a problem with your sensor. Tell them to maybe try to replace the sensor, and see if it turns off, if not you have a wiring issue.
Old Aug 22, 2008 | 01:05 PM
rody_mr's Avatar
light stays on and when the belt is connected it turns off.
Old Aug 22, 2008 | 04:08 PM
nunyas's Avatar
it flashes with someone in the seat not wearing the seatbelt...
Old Aug 25, 2008 | 04:14 AM
kalpakiotis's Avatar
If noone is in the seat and the light still flashes it could be the seat position is not in a full position. This was an issue with some other people on this forum.. This topic was already discussed and it has some other info in it. Sit in ur seat and move it back and forth then make sure it locks into a position. That should do the trick.
Old Aug 25, 2008 | 05:59 PM
nunyas's Avatar
yeah... what Kalpakiotis said...
krypt952
May 28, 2016 04:07 PM
hispanicpanic
Apr 18, 2016 12:03 PM
Johnr352
Dec 23, 2010 07:20 AM
kcandiloro
Nov 24, 2009 12:55 PM
