headlight keeps burning out
Old Nov 15, 2003 | 10:37 AM
swhskenr's Avatar
i'm surprised no one is offerring the real solution j/k..
it is only burning out due to a fuse issue.. upgrade ur fuses under the dash up 5.. that will fix the problem..
PM me if u need help...
Old Nov 15, 2003 | 10:54 AM
rentaslut's Avatar
i've blown about 6 aftermarket bulbs. at first i thought i may have touched it, but nawww its the cheapness factor for sure. I bet when I put in the new PIA's or whatever they'll last a year..
psionic98's Avatar
I had a pair of 3A bulbs, bluish tint 4200k... driver side blew out just over 1 year, and the other one went out 2 weeks later.. went back to the silverstars I had in the closet... lets see how long these last
Old Nov 15, 2003 | 11:06 AM
lancer02Josh's Avatar
the fuse is already at 10, what do u mean upgrade to 5
Old Nov 15, 2003 | 11:08 AM
do you mean make it 15??? will that cause problems???
Old Nov 15, 2003 | 01:09 PM
jason33hs's Avatar
Your problem is cheap bulbs. I upgraded to higher wattage bulbs and one blew low beam only after 5 months. The fuse will not affect the bulb itself. The fuse may not hold the load that a higher bulb creates, but the fuse should fail first then. Most bulbs that sell around the $20 range are not quality, high-performance bulbs thus the price.
Look for a reputable, name brand manufacturer such as Hella, PIAA, or even Sylvannia for brighter bulbs. Maybe even web-search for rally lights-those guys know lights best.
Best of luck.
Jason
Old Nov 15, 2003 | 05:15 PM
swhskenr's Avatar
trust me.. i have not had any problems.. i use high wattage piaa's.. sh** brand cheapos.. no problems.. i've had the same pair for ever..
nokya's..
Old Nov 17, 2003 | 11:41 AM
Blacksheepdj's Avatar
Eurolites - driver side just blew after 3 months. I understand. PIAA looks tempting...
pratik
Apr 26, 2017 03:46 AM
joonvang
Oct 31, 2016 04:09 AM
tiesto14
14
May 19, 2016 08:52 PM
TxFAkuma
Sep 30, 2015 08:55 AM
yahu
Mar 24, 2009 08:09 AM
