09 GTS, CVT wouldent change ratio
Old Feb 18, 2010 | 09:10 AM
timo606's Avatar
Car; 09 lancer GTS with CVT and paddle shifting, no modifications (14499 miles)
I was pulling out of a parking lot (car was fully heated up) and my front passenger side wheel lost traction (I hit a patch of gravel) and regained traction a second later, about 3 seconds later I noticed that the engine was revving up like I had the car in manual mode. I was not in manual mode and D was displayed on the info display and the car shift lever was also in Drive mode. I quickly moved the shift lever to manual mode and shifted up without a problem. The RPMS never got above 4000, but it did catch me off guard and now im worried about my car.
Any else had this problem? Could there be a problem with the tranny? What could of caused this? Is it safe to drive my car? should I go to the dealer?
Any info will help thanks!
Old Feb 18, 2010 | 10:34 AM
Defcon5Es's Avatar
Suck to have icy driveway. But you should be fine the computer probably thinks you still loosing traction. No worries.
Old Feb 18, 2010 | 11:05 AM
CamShaft's Avatar
If it happens again it will most likely light your check tans. light. Until then, I wouldn't worry about it.
Old Feb 18, 2010 | 11:18 AM
lancer0220's Avatar
same thing has happened to me before when a wheel loss traction but as soon as the computer recognized where it was it got back on "track" , key is to not keep applying gas when this happens, lay off the pedal and wait or drop it to manual mode
Old Feb 18, 2010 | 11:31 AM
evo_soul's Avatar
This is exactly a problem, its more a flaw in CVT logic.
I have had this happen to and its very strange, in my case it sometimes happen (rare) when i am making a left hand turn, its my turn, and waiting for that break in traffic so I can accelerate and complete the turn. Sometimes on a cold day I will hit a patch of black ice and the wheels will spin.
Now somewhere in the CVT logics there is something that causes it to think its going at a faster or slower speed than it really is. Once you drive for a bit, your car should once again realize its going at a normal speed and the gear ratios will come back in line with what your throttle input is.
It shouldnt trigger a code, if it does then I would most certainly go in and get it checked out.
Other than that, its something within spec and can happen. (not normal, but acceptable)
Old Feb 21, 2010 | 03:17 PM
timo606's Avatar
Alright then thanks for the info guys! very helpful.
Old Feb 23, 2010 | 08:09 AM
CamShaft's Avatar
you think the cvt would also talk to the ABS ECU on the datalink and see that the rear wheels are not going anywhere. I guess that would be more of a traction control not included in our model :P
Old Feb 23, 2010 | 10:47 AM
evo_soul's Avatar
correct. But since each system must be independantly run. I think your correct to hint that the traction control version of our car (touring edition) would likely not have this problem.
Then again... its a very complicated CVT programming thing. lol programmers might just say F' it! and call it a day.
hccyong
Mitsubishi TC-SST Discussion
15
Jun 3, 2015 04:24 PM
lavar56olb
Lancer Engine Tech
Feb 26, 2010 09:50 PM
Webman
Mar 6, 2009 03:55 PM
A1smithkid
16
Jun 8, 2008 12:32 AM
fr0nz
Lancer Tranny/Drivetrain Tech
19
Dec 7, 2007 09:29 AM
