Need some help!
Old Mar 16, 2010 | 11:40 AM
EvolutionESX's Avatar
Need some help!
Hey everyone
02' lancer oz with 124k stock. I noticed that when i turn on the car (cold) it revs up to 2,200 rpms for about 3 sec then slowly lowers to about 1,100 rpms until the car warms up normally then at normal temp, sits at 600 RPM (is this normal?) Then when i shift it into any gear from park or nutral instead of the RPMs lowering because of the load like normal the RPMs increese and hit 1000RPM before the trany gets into gear, then sit at 850RPMs+- 50 when in gear, also vibrates alot only under load, disapears in park or nutral or if i increese the RPMS to 1000. Could a clogged EGR or IAC cause this? I had a P0301 code cylinder 1 misfire and wires and plugs gapped at 0.042 took care of that prob, also replaced the air filter, pcv valve and oil filter and oil. Trans fluid is light transpearent color and smells clean and is at the proper level when hot and run in every gear prior to check. But i have a P0442 small evap leak code now, dont know if this is related? Any input would be greatly appreciated!
-Tony
Old Mar 18, 2010 | 12:06 AM
turbolancer02's Avatar
Originally Posted by EvolutionESX
Hey everyone
-Tony
its normal for the high rev on startup ...cars shipped to colder climates have a cold start flash built into the ecu program...it gets the stuff up to temp faster ...I would reset the computer by unhooking the battery , check the gas gap and or replace it and see if the code reappears
Old Mar 18, 2010 | 05:07 AM
Thanks for the info man, interesting i never knew that! I replaced the gas cap the old one had some cracks on the o-ring, i reset the ecu (unhooking the batt) and after 75 miles i got the light again. This code sucks, i guess it can be up to 0.020 of an inch hole.. But is it still normal for the car to high rev when putting the car into gear? At "P" or "N" the car idles around 650. when putting it into gear it revs up to around 1000 then gets into gear and the rpms rest around 800-900 in gear
Old Mar 18, 2010 | 10:43 AM
ClixT's Avatar
what was the code? get it scanned.
probably your code is about idle too high.
Old Mar 18, 2010 | 01:33 PM
No the only code i have is P0442 evap leak small leak. they told me it can be as small as 0.020 of an inch, wtf seriously? how am i going to find that?! who makes these codes haha
Old Mar 19, 2010 | 09:33 AM
ClixT's Avatar
thats a freakin small hole. lol
Old Mar 19, 2010 | 09:50 AM
seriously hahaha why would you make a code for that its rediculous. I guess ill just have to start replacing hoses! Is the trans filter on an auto 01 oz replaceable after the pan is off? i know its usually a non-service part but if its easy to get to when the pan is off i might as well do it.
Old Mar 20, 2010 | 01:02 AM
there is no filter , its a screen and its not replaced as a service item....I assume you mean an 02 oz...
as far as the leak Im an ase tech at mitsu , Ive never seen that code where it wasnt the gas cap, but keep us updated on that
Old Mar 20, 2010 | 07:46 AM
UPDATE***
the p0442 code was a faulty gas cap, the oring had many small spyder cracks on it.. now i have a p0456 (evap very small leak detected) where the hell am i suppost to find this one guys? I did do a vac test on the purge solinoid under the hood.. the purge solinoid did not hold vacumm with the car on of off, im guessing this could be the problem?
Old Mar 21, 2010 | 09:57 PM
mantella's Avatar
p0442 can be a ton of things and is pretty common among all cars. On mitsu the main thing i have seen is the canister vent valve or loose gas caps. But sometimes it is just a bad gas cap.
Old Mar 22, 2010 | 08:21 AM
Im going to be replacing the canister vent valve next because at first i tested the purge solinoid and it held vac so that couldnt be it, i inspected all the hoses i could find and they looked suprisingly well. I replaced the gascap with a brand new OEM one from mitsubishi, re-set the code and it came back on within 40 miles. So im thinking that the vent valve may be the culprit here. Is there any way to test this befor repacing?
Old Mar 25, 2010 | 09:15 PM
EdT's Avatar
EdT
Check or change your PCV after 48kms, under $10- and saves you tons of gas and more engine power !
Old Mar 26, 2010 | 10:51 AM
I have changed my PCV already about 2,300 miles ago! I replaced the vent valve near the canister, was good for 98 miles then came back on. Im sending it it mitsu to be looked at i dont want to keep buying expensive parts to find out it was a pin size hole in one of the lines.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
amiller80
May 9, 2017 06:55 AM
tequila357
Feb 18, 2016 11:42 AM
GsrJake
Dec 11, 2012 10:35 AM
