Severe Electrical Issue, Lots of things not working!
Old Sep 3, 2010 | 12:26 PM
TutMatt3's Avatar
Things not working, (no power at all):
Stereo
Dome Lights
Door locks (both from key and the inside switches)
Things that super confuse me:
When the key is turned to accessory position (not on) nothing even lights up!
When the key is fully on, then the switch on the door to lock/unlock works ????????
Things that happend:
I had my middle dome light that was out, so i thought it was a fuse, i went ahead into the fuse box, and got my plyers
I went for the fuse (if i can recal, fuse #9) and before i even was able to pull it, a spark flew!! Then another. tiny sparks, but enough to worry me
I think this might of been caused by my plyers resting on the metal frame before the fusebox, when touching the fuse
The interesting part that happend is, the fuse did not blow.
But this is when hell broke lose. Nothing was working now
Then all those problems came, now all the dome lights are out, radio doesnt have NO power, and key issue is still happeneing
Took it to the dealer, since I have an aftermarket radio, they wont even touch it under warrenty, want 100$ for first hour and $150 each hour after
Took it to a mechanic, had him check all the fuses. all are good. I even swapped a lot of them. Nothing
Could the dealer be right, and it has to be something with the radio instaall (which was installed a year ago), but didnt trigger anything bad untill i tried puling a fuse??
*bangs head* this sux :/
Old Sep 3, 2010 | 02:32 PM
M@verik's Avatar
First thing I dont understand is why were u trying to remove a fuse with pliers?
Old Sep 3, 2010 | 02:49 PM
evo_soul's Avatar
who did the install of the stereo. first place I would start is there.
Your dealership is entirely right. Your stereo is a major upgrade having to do with electronics. If its not done right you have severe issues. All of which is not the responsibility of Mitsubishi.
If you had it installed to a pro, go back and report the issue to them. They may be able to quickly go in there and find out what might be the issue "if" its related to the stereo. Since I dont know how hardcore your stereo is. its to hard to diagnose here.
Old Sep 3, 2010 | 08:24 PM
TutMatt3's Avatar
With pliers is b.c im a dumbass :/, they were needle nose at least
And ya im having a pro audio installer check it out tomorow
Is there any such "reset" mode or something that can reset the computers ecu, like a refresher?
Two more additions:
I unplugged my battery for 20 minutes both connections, and nothing
The screen in the begining (that shows average milage, ect) resets everytime i put my key in
It changes from average mileage back to TRIP A 0.0, then ill drive for 15 miles or so, and when i restart it, its back on TRIP A 0.0, like i unplugged the battery or something :/
I hope none of the wires melted together behind the fuse box, but at the same time, it would be an easy fix, just hard to get to
Old Sep 3, 2010 | 11:24 PM
02-Lancer-Es's Avatar
You might have fried the Estacs Ecu or what ever its called i did the same thing when i was changing out a dome light bulb while it was still on the "On" position .
Old Sep 4, 2010 | 01:00 AM
TutMatt3's Avatar
ya i was an idiot and i tried pulling the fuse while the dome lights were on ://
Old Sep 4, 2010 | 01:01 AM
TutMatt3's Avatar
do you think you can please please find out the name of that ecu thing? i couldn't find anything on Estacs Ecu
Old Sep 6, 2010 | 02:47 PM
TutMatt3's Avatar
issue fixed. was a fuse under the hood that blew, even tho i didnt touch it, the 30amp one i think, that has the fuse holder resting on it
Old Sep 11, 2010 | 04:04 PM
Greedy_son's Avatar
^ better a fuse then all your electronics. Its just a pain to try troubleshoot lol.
Old Jun 21, 2011 | 06:28 PM
ppch8's Avatar
sorry to bring back a dead thread. I have the same issue with my car.. my issue is identical to yours. and i have checked every fuse and seems ok. I might of missed the one that you replaced. what was the fuse for that you replaced? oh and btw this is for my Evo 7, cant seem to find one that has similar issue on an evo then i found your thread.
things not working
1. cant lock my car with key only works when its on ignition
2. door chime
3.radio
4. clock
Old Jul 2, 2011 | 11:01 PM
CamShaft's Avatar
Did you check the maxifuse/relay compartment in the engine bay?
things not working
2. door chime
3.radio
4. clock
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
Boston'sEvO-->8
May 3, 2021 04:18 PM
Tomukas
Jun 20, 2017 10:10 PM
Fox5.56
Apr 18, 2017 05:13 PM
TxFAkuma
Jul 20, 2016 02:02 PM
