2002 Lancer heat control unit bad?
Hello, I just bought this Lancer and I noticed that the control dial you use to choose defrost, air at feet, etc. only goes halfway and it where it does go, it doesn't change the route of the air. In other words it comes out at face level only no matter what I do with the dial. Also the far left dial, the one where you choose how cold or hot it blows does not seem to allow hot air to come through. It is set on cold. Finally, at idle the A/C doesn't seem to work. It only works consistently when the car is at speed. I am at a loss. Any advice? Thanks!
Don't crank on the knob too hard. It was a technical service bulliten to replace the gears for the knobs. It reduces how hard you need to turn on the knob. I got the parts from Mitsubishi for around $25 - they also have other parts in the TSB but you need to remove the dashboard to change the stuff out. More than I wanted to handle. Don't break the knob linkage then you have to replace the whole in dash unit for a ridiculous amount of money.
Lightsaber
Apr 19, 2016 10:39 PM
tucknroll
Lancer Troubleshooting
Mar 25, 2016 08:03 AM
hearnoevo
Dec 2, 2015 09:12 AM
