Rattling From Front Right of Car
Old Feb 28, 2012 | 01:40 PM
campbmic's Avatar
Yes it goes away while braking even on large bumps and stuff
Old Feb 28, 2012 | 08:41 PM
CrAnSwIcK's Avatar
you're sure the calipers are tight? what about the wheel lugs?
Old Feb 29, 2012 | 11:35 AM
campbmic's Avatar
Caliper is on tight and wheel is on tight. Since the rattling started 50k miles ago I have done quite a bit of work on the car and taken the wheel and caliper on and put it back on a few times. I even did a clutch swap and tightened everything down to torque spec that was involved in the swap. A front suspension diagram would be awesome if anyone has one!
Old Feb 29, 2012 | 01:17 PM
CrAnSwIcK's Avatar
what about the axle nut
Old Mar 1, 2012 | 12:26 PM
campbmic's Avatar
Yes that is all fine its coming from somewhere behind that area
Old Mar 1, 2012 | 03:11 PM
campbmic's Avatar
So I have the car on stands, wheel, caliper, rotor, and strut removed. I have the control arm disconnected from the knuckle.
It looks like the mechanic welded one of the control arm bolts in. Do you think this might be the problem?
Attachment 337503
Maybe he stripped out whatever that bolt screws into and now there is a little movement in that spot?
http://www.youtube.com/watch?v=NoMf-...ature=youtu.be
Do you guys think this is the issue? How might I go about fixing it? Where does that bolt go to?
Old Mar 1, 2012 | 05:02 PM
eusgen's Avatar
I would say you might be onto something, fixing it however looks to be a chore.
Old Jul 19, 2013 | 07:20 AM
GhostAWD's Avatar
To anyone reading this thread / future readers:
I also had a "jingling" metal to metal sound coming from the front drivers side suspension, turned out the bracket that holds in the brake lines had come loose just enough to move around when air hits it, tightened it down no more noise ....
migs647
Evo X How Tos / Installations
202
Sep 16, 2020 02:25 PM
eV0_n00b
Oct 2, 2014 02:49 PM
gkew
Aug 3, 2013 11:19 PM
boobcakes
55
Dec 19, 2011 10:05 PM
campbmic
Lancer Tranny/Drivetrain Tech
Oct 20, 2010 04:05 PM
