Broken Buschur Filter
Old Jan 21, 2004 | 01:21 PM
darkknight206's Avatar
Exclamation Broken Filter
HELP! I just bought the Buschur Racing Intake and I was trying to install the filter when one of the bolts broke off. I dont really want to buy a new one or call up Buschur Racing. What can I use to reattach it? Super Glue? Solder? Leave as is?
Old Jan 21, 2004 | 01:24 PM
zupber4930's Avatar
Weld it...find a local shop...shouldn't cost more then 10 bucks
Old Jan 21, 2004 | 01:25 PM
Would a Soldering work? I dont want to spend any Money.
Old Jan 21, 2004 | 01:35 PM
digdat's Avatar
did it break off, or fall out? Can you tell how the other 3 bolts are being held into place?
You could probably use some JB-weld to re-attach it to the plate in the pic (built in mas adapter I assume) and then bolt it from the other side. You could also try removing the filter from that plate, shove the bolt through, bolt it to the mas nice and snug and then re-attach the filter??
I would also call/email Buschur and see what they recommend. Always a good idea, that way they also know about potential issues they are having in the "field".
dig
Old Jan 21, 2004 | 02:00 PM
It broke off of the filter bottom plate (Yes, that is a built in MAS adapter). The nut was semi-welded to the plate from the inside. I say semi-welded because it looks like they only welded each nut in three spots. I've PMed David about it but he's not on right now so I'll have to wait.
Old Jan 21, 2004 | 02:09 PM
UFO's Avatar
UFO
Did you break it bending the bolts out so that it will actually align with the holes in your MAF? I'm pretty sure mine came close to breaking when I did that. All 4 of my bolts were facing towards the center. JB Weld would probably work because you just need something to hold it in place while you tightn the MAF on, unless it breaks loose when you try and take it off next time round (that would be fun). I'd either get it tack welded again or send it back.
Old Jan 21, 2004 | 02:14 PM
jtc's Avatar
jtc
what's the big deal? once you bolt it on, it'll be tight, won't it? unless the bolt's going to turn while you're trying to put it in.
Old Jan 21, 2004 | 02:16 PM
UFO's Avatar
UFO
You just answered your own question.
Old Jan 21, 2004 | 02:24 PM
Sailorgoon's Avatar
You'll need to have it tack welded to prevent it from spinning. It's gonna cost you a few bucks, but it's cheaper than a replacement plate from Buschur. There really isn't any way you'll fix this for free, unless you know someone who will tack it for you.
Sweet air hocket table, BTW.
Old Jan 21, 2004 | 02:34 PM
zlancer's Avatar
you can probably use some steel/metal epoxy...sand it a little and use the epoxy and that **** should never come off.
Old Jan 21, 2004 | 03:37 PM
Do those epoxies withstand heat very well? I'm just worried about it melting cause of engine heat and then I'd have a big problem. Also how much do those cost and where can I find them? But I still would like to know if soldering would work. And if you dont know what soldering is solder is the stuff used on things like computers to connect transistors and other metal wireing. It has a melting point of about 136 degrees F.
EDIT: OK, never mind about the heat question. I went to the store and found some epoxies (didn't buy : forgot money) and they withstand up to 200 degrees f. If my intake heat got over 200 degrees I think I'd have much more to worry about than the epoxy.
Old Jan 21, 2004 | 04:13 PM
This is solder
Old Jan 21, 2004 | 04:58 PM
sdhotwn's Avatar
you can prevent it from turning by using one of those "star" washer. It'll hold still once you get it tighter. The star washer will bite in. The cost about 2 cents...
Old Jan 21, 2004 | 05:02 PM
cerfur's Avatar
star washer might work alot tof saulder could work as well as some good epoxy
Old Jan 21, 2004 | 09:58 PM
Ya, im just going to use some epoxy thanks guys for your help! (So much for not trying to spend any money)
Ya, I like it too. Its good for parties. It also works as a handy work bench, too.
