Fast Tapping/Clicking noise while in Drive 2004 Lancer ES.
Alright, this noise doesn't happen sometimes.. But when I'm stopped at a red light or stop sign I get this fast clicking/Tapping sound. I don't know if it's coming from my engine I can only hear it from inside the cabin it seems like it goes away when I put it in neutral or Park. When I press on the gas the noise is completely gone and does not get faster or louder with accelerating but goes away. I opened my hood while in drive with the ebrake and listen with a long piece of wood to the internals but couldn't head the noise inside.. It's really bothering me I need to know if its serious I have no money for the mechanic and the car has oil I have in it 3 quarts lucas 10-30 then. The stabilizer for newer computer controlled cars..any suggestions would be great thank you so much.
It has 3 quarts of Lucas 10w-30 and 1 quart of the Lucas oil stabilizer, it does go away SOMETIMES.. But:/ it makes the noise most of the time it's annoying I use Mobil gas in it. Not sure if that's a good gas company it's 3.78/gal vs. 4.00/gal it started making that noise probably after 2 months of using that gas station. Anything I can add too clean the lifters.. I don't think I can stand the noise much longer even though it's
not loud it just worries me if it goes down I have no transportation.. Any ideas please?
It doesn't sound like a problem with your fuel system at all. Though there are a few things you can do if it'll make you feel better. I.e. new fuel filter, fuel system cleaning( cleans throttle body and injectors). Ticking/tapping is a fairly common thing with lancers. Have heard from many mechanics that its supposed to sound like a sewing machine. If you haven't been properly lubricating the engine( getting regular oil changes every 3000 miles) it will deffinatly make the noise louder.
Clicking noise in 2002 mitsubishi lancer oz rally cause and solution
The reason for the clicking noise you are hearing is due to poor oil maintenance. Check your cars oil if it is low which it most likely will be, add a half a quart to a full quart as an immediate solution for the time being. You must go get an oil change ASAP, and continue to get oil changes every 3000 miles. Use 10w 30 high mileage mobile 1 full synthetic oil if your car is over 100000 miles. If it is below I recommend you use 5w 30 mobile 1 oil. Non turbo mitsubishi lancers are supposed to take 5w 30 conventional oil but my 2002 mitsubishi lancer oz rally has over 175000 miles and is still running strong because of my switch to full synthetic. Your welcome!
It could be one(or a couple) of your lifters are a bit gunked up causing a bit of clatter, not a major issue. There is a procedure for cleaning the lifters, but they have to be removed from the car and cleaned with diesel fuel. Next oil change switch to full synthetic, they typically have a better additive package as far as keeping things clean goes.
LCS
Jul 11, 2016 09:16 AM
