Catalytic Converter Issues!!!!
Old Jun 16, 2014, 07:01 AM
Dapperlancer's Avatar
hey guys first off i drive an 03 lancer es. i recently had a check engine light come on so i took it to get checked and the reading that came up was that my cat was clogged, which makes since because the car has been showing all the symptoms of a clogged catalytic such as needing to be in really high rpm's before switching and strange rattling sounds while accelerating. my question is....
1.) can i just remove the cat altogether and just straight pipe to a muffler? if not why?
Old Jun 16, 2014, 07:37 AM
eusgen's Avatar
You can as long as your state doesn't require an inspection
Old Jun 16, 2014, 07:52 AM
Metalsoft1's Avatar
You can, but it's not legal. Not good for the environment either. Smog regulations are there for a reason.
If it is the 2nd cat ( under car ) you can get a Magna Flow Cat for it for around $100. It will cost about $30 or $40 bucks to have it welded in.
If it is the front cat ( headers ) you might* find a shop that will replace that cat, if not you will have to buy the header assy. which is around $299 to $325.
If you do it right, you car will last longer and run better. Deleting cats/mufflers are not what it was designed to do.
Old Jul 23, 2014, 04:55 PM
Lancerprobs's Avatar
I am having a hard time finding a after market front cat less than $375 dollars. I'm in California so it needs to be cali legal. Do you have a link by any chance? And if I can find anything cheap enough how would I go about about asking a shop to replace the front cat and not the whole assembly?
Last edited by Lancerprobs; Jul 23, 2014 at 04:57 PM. Reason: adding more information
Old Jul 27, 2014, 06:52 PM
02modlanceroz's Avatar
I have a stock header laying in my garage with around 60k miles on it. Was good when I took it off the car. Pm me if you would be interested.
Old Jul 28, 2014, 09:34 AM
I don't think I can Pm because my account is new. Either try PMing me or reply to this message. But I'm in California, how much are you looking for shipped?
danike
Jan 16, 2014 08:25 AM
evo4life94
15
Oct 17, 2012 04:36 PM
PCToolsWiki
May 26, 2012 07:00 PM
TRASHY_GTS
Toronto Lancer Club
15
May 18, 2010 04:38 PM
RNSpeed
Nov 14, 2009 12:09 PM
Quick Reply: Catalytic Converter Issues!!!!
