Random misfire only at operating temp
Old Jul 3, 2015 | 11:39 AM
  #31
ATM Blazin's Avatar
Cranked it over by hand a couple rotations and those were the only ones with play throughout each stroke, they stiffened up about halfway through but then back to having play. So i took the rail and rockers off and felt the cam to check for grooves or chunks missing, everything felt smooth, so im leaning even more towards the lifters now
Old Jul 3, 2015 | 02:11 PM
  #32
CrAnSwIcK's Avatar
if none of the other came loose at all (I'm talking .008-.012), through I think 6 rotations, then you have a problem....which is your valves may be sticking open...but if that were the case, you would have had poor compression...and that would have led us to this conclusion sooner...cylinder one, may just be very loose, and would cause an awful racket, but it's adjustable...adjust it and carry on.
Old Jul 4, 2015 | 12:11 AM
  #33
ATM Blazin's Avatar
When i looked up if they were adjustable the thread on here said they weren't
Old Jul 4, 2015 | 09:15 AM
  #34
CrAnSwIcK's Avatar
oh right...sorry, I'm thinking of 4G6 engines...it's been a while now since I had my 2003 ES...
you can however, bleed or replace the lash adjusters...but the thing about that is, that will cause excessive noise but should not affect engine operation...
Old Jul 4, 2015 | 11:19 AM
  #35
ATM Blazin's Avatar
So, should i just go on the hunt for a head and call it a day, this is seeming like too much chance at this point, there's also a salvage yard by me that my dad used to do business with when he had a shop, they have an oz with a motor that only has 90k miles (compared to my 163k , much better) its starts and runs good and they take it out for me for only 500 , only thing is I've never taken a motor out of a car, so not very confident of my ability to do that alone even though everyone is telling me it's easier than all the other work I've done, like the oil pump, which seemed pretty straightforward
Old Aug 15, 2015 | 07:47 PM
  #36
sxperia101's Avatar
Bought a 2002 lancer gdi engine in April, been busy havent got a around to get it fully ready. The previous owner havent drove it in years. what are the parts i should change???? oh i noticed that whenever i get to 2000rpm or higher the gdi eco comes off
gsujeff55
May 4, 2006 04:47 AM
Boost Addict
Dec 6, 2005 10:05 PM
Derek888
Feb 19, 2005 02:52 PM
