Grinding noise during start up
Old Sep 10, 2017 | 12:32 PM
Dstorm7's Avatar
Hi all,
When starting up my car there is a grinding noise, the starter has been replaced, but still there is the grinding noise.
When driving the car drive perfectly, no noise when driving or idle.
Anybody have an idea and when i checked this on the web I read about the flex plate could be damaged.
My car is an automatic cvt DE 2009.
Thank you in advance
Old Sep 10, 2017 | 02:22 PM
SnowGT's Avatar
Hello friend,
Can you remove your starter? So you can inspect the teeth of the plate, if you see damaged or bended teeths there is the problem, also see if the movement is linear, if the movement of the plate is waved or so, it is the problem
Old Sep 10, 2017 | 06:44 PM
Dstorm7's Avatar
Hi SnowGT,
I will take the starter out and check it.
Just a question, do you know if the Mitsubishi lancer starter have some sort of plate/ gasket that fit over it, before it connect to the flex/drive plate?
Someone told me that the starter might be sitting to tight on the drive plate.
Can this be true
Old Sep 10, 2017 | 09:26 PM
SnowGT's Avatar
Nope, there is no gasket nor something between the starter and the block, it bolts directly, that reason can be true for other engines but not for this.
Don't forget do a 360 degree inspection of the plate turning by hand the engine
vassili
Feb 24, 2015 07:06 PM
sc_s13
Sep 28, 2011 05:32 PM
shabsralliart
Sep 27, 2010 10:32 PM
QuanVN
Apr 30, 2010 03:40 PM
RussellM
MitsubishiParts.net - WA
Jan 8, 2008 05:29 PM
