Sponsored by:
Sponsored by: CARiD
normal to hear grinding noise during slip on MR?
Old Feb 13, 2015 | 06:24 AM
vassili's Avatar
i'm sliding and doing donuts in an empty parking lot full of snow.
when the car is losing traction (mid slide), the info screen flashes yellow and i can hear some grinding/mechanical noises coming from underneath me. i assume it's the differential? this is normal right?
Old Feb 13, 2015 | 06:35 AM
hoobastnk90's Avatar
i think it would be a safe bet that grinding is never a good noise. I was also doing that once and was really gettin it and started to hear a bit of a huming or mechanical noise from the rear and decieded welp im not doing that ne more. That was 20k miles ago and so far so good.
Old Feb 13, 2015 | 07:30 AM
Ev0ikon's Avatar
What the? I do it all the time in the wet. Never heard a "grinding" noise.
Old Feb 13, 2015 | 08:19 AM
vassili's Avatar
awww man, i was afraid of this. i wonder what it is. i have traction control fully on though.
Old Feb 13, 2015 | 08:59 AM
LB_Reddy's Avatar
The ayc is kickin in on slip roads.Turn the asc off
Napalm_Enema's Avatar
Try with traction control off and see if the noise is there?
Old Feb 13, 2015 | 09:04 AM
make sure traction control is off off then try it!
Old Feb 13, 2015 | 09:58 AM
vassili's Avatar
ok, so with ASC fully on, it's supposed to make a noise right?
Old Feb 15, 2015 | 09:24 PM
LB_Reddy's Avatar
Its normal .When asc fully on noise occurs only on slips.sounds kinda like abs brakes.It wont happen when asc is off."If u drive and still hear grinds its not normal.
Old Feb 24, 2015 | 12:42 PM
vassili's Avatar
i don't think so. abs usually rumbles on the brake pedal no? i don't feel anything on the pedal. it sounds like metal scrapping it's starting to happen on quick turns now. no slipping. but only when it's really cold outside and within the first 5-10 min.
weird!
Old Feb 24, 2015 | 02:02 PM
CharChar's Avatar
AYC activating was my first thought too. I don't think you'll feel AYC kicking in on the pedals cuz it only happens on the rear wheels.
It could also be the wheel hub if it has some play in it. I had a metal grinding noise from my front driver side wheel. It took me a while to figure out that the wheel hub is a bit loose. It was happening intermittently and when I brake hard, it would go away.
Old Feb 24, 2015 | 07:06 PM
LB_Reddy's Avatar
Mine ayc does that.i dont feel it from the pedal,its coming from the drive line and when my x is low on fuel the ayc auto disable.
Dstorm7
Lancer Troubleshooting
Sep 10, 2017 09:26 PM
LT1runner
Mar 10, 2010 09:10 AM
RussellM
MitsubishiParts.net - WA
Jan 8, 2008 05:29 PM
MalibuJack
50
Oct 5, 2004 09:13 AM
