problem with ac controls
Old Jul 22, 2004 | 04:52 PM
buzzs125's Avatar
Angry problem with ac controls
Has anyone had problems with their blower speed switch in their lancers? The problem I have is that from 1 to 3 the blower doesn't blow any air in the car, but on 4 it blows at max speed but with no ac. When I put the switch in 1, 2, and 3 the ac button will light up when I select it, but when I put it to 4 it goes off, and won't light up even if I press it.
Old Jul 23, 2004 | 11:16 AM
lancerasu's Avatar
if your car is still under warrenty and you haven't vioded warrenty yet...take it to the dealer...let then fix that ****...that is what i did with my ac control, but mine was sticking...they should fix it for free...good luck with that though
Old Jul 23, 2004 | 11:20 AM
HobieKopek's Avatar
Definitely dealership issue. Don't even bother with the HVAC yourself.
Old Jul 23, 2004 | 03:21 PM
buzzs125's Avatar
I took it there today and they said it was a blown resistor for the blower.
Old Jul 26, 2004 | 11:41 AM
HobieKopek's Avatar
Nice and simple fix assuming the resistor is easy to access.
Old Aug 6, 2004 | 08:32 PM
buzzs125's Avatar
Ended up being a simple fix. The resistor is behind the ECU.
Old Aug 23, 2006 | 04:29 PM
tjbartjr's Avatar
Do you happen to have the part number for that resistor, since I'm having exactly the same problem as you. Correction, my fiancee is having that same issue in her '02 Lancer.
Old Nov 8, 2007 | 02:13 AM
Tankmalone's Avatar
i know this is an old thread, and idea what that part number is?
Old Nov 8, 2007 | 08:53 AM
Tech@SA573's Avatar
MR568591...I think. It says "heater resistor", but it's the only thing that shows up in CAPS for "resistor".
Old Jul 15, 2008 | 01:21 AM
Miira's Avatar
Can anyone tell me where to find the heater resistor on an '04 Lancer OZ?
Old Jul 17, 2008 | 06:26 AM
jody-z's Avatar
Yup, its located behind the glovebox, then, you have to unbolt and slide-down the ECU partially and it's right behind there. Do a search for "Blower Resistor" and you'll get more results.
Old Jul 22, 2008 | 04:57 PM
getsideways's Avatar
https://www.evolutionm.net/forums/sh...lower+Resistor
Heres instructions
Old Mar 14, 2009 | 08:48 AM
jody-z's Avatar
If anyone runs into this same problem, review the discussion at:
https://www.evolutionm.net/forums/la...may-going.html
After much thought, it was confirmed that my blower/motor was starting to rust, which was causing it to draw too much current, causing the blower resistors to die.
Dallas02ozRally
27
Nov 18, 2023 11:38 AM
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
kd5byb
Sep 7, 2013 05:44 AM
W_evo8
Mar 29, 2009 01:39 PM
xphillipjrx
Aug 4, 2007 07:46 PM
