Doors that wont close in the summer and broken cruise control
My 2003 OZ Rally has 21K. The past two summers the doors don't close when I close them they stay open, I think it might be some grease things or something but i'm not sure. Has anyone else experiance this? How can I fix it?
Also since I bought the car the cruise control isn't right. I had the dealer look at it and of course it worked fine for them. Once in a while when I go to set it, it doesn't take and I can try again and again and again and still doesn't work. Then other days it works fine. The weather doesn't matter either, happens in sunshine, rain, snow etc. . . If you have any suggestions please help!
Happy driving everyone!
Won't CLOSE or won't LOCK?
Your description of the cruise control problem leaves much to be desired. The more info you give, the more likely you'll get something helpful back.
The doors don't close, when I shut them they swing back open like tossing a ball on the ground. Also The cruise controld problem I don't know how to explain it. It happens randomly, it doesn't matter what speed I try setting it on it won't take. I push the button in to set it and it doesn't do anything. The light comes on on the dash that says it's on but nothing happens. I don't know how else to describe it. Thank you for all your feed back
