STi numbers drop in 2007
Old Oct 17, 2006 | 08:07 AM
tuffguy's Avatar
Due to the new testing SAE methods:
2007 STi: 293-hp @ 6000rpm & 290 lb-ft of torque at 4,400 rpm
2006 STi: 300-hp @ 6000rpm & 300 lb-ft of torque at 4,000 rpm
2007 WRX: 224-hp @ 5600rpm & 226 lb-ft of torque at 3,600 rpm
2006 WRX: 230-hp @ 5600rpm & 235 lb-ft of torque at 3,600 rpm
Old Oct 17, 2006 | 08:09 AM
EVO Neil's Avatar
I knew it! We dynoed the cars for the last two comparisons we did and the STi's were always low, sometimes lower than the Evo, which it shouldn't have been. It's about time they came clean.
Old Oct 17, 2006 | 08:11 AM
boostinjuice's Avatar
thats sux
Old Oct 17, 2006 | 08:12 AM
DRFTKNGG's Avatar
Finally the truth comes out! Who where they kidding? I use to stomp on STI's when I was stock and they had a boost controller and exhaust...Still wasnt a race...lol.
Old Oct 17, 2006 | 08:14 AM
purecoda's Avatar
link to proof?
prostcj's Avatar
I don't think it is an actual decrease in hp, just different testing method.
Old Oct 17, 2006 | 08:21 AM
Kordwood's Avatar
Anyone know how the Evo rates under the new standards?
willum14pb's Avatar
Theres a new HP rating system, which is why you'll see other cars rated lower as well, everything is ~ 7hp lower than what they were the year before basically.
Old Oct 17, 2006 | 08:24 AM
shiftdsm E's Avatar
maybe they are adding load to the power measurements, think dynojet vs dyno dynamics or mustang. obviously its not an at the wheels measurement but still a little closer to what you would actually be putting down.
Old Oct 17, 2006 | 09:04 AM
firehawkta2000's Avatar
I actually think that many GM vehicles went UP in power with the new methods...
Old Oct 17, 2006 | 09:09 AM
Grav's Avatar
Actually this is not entirely true. Most of the cars that saw a drop in their advertised HP were imports. Even the Camry got hit by it. However many domestic cars actually saw an increase in their HP numbers under the new standard. The Z06 for instance, got rated 5hp higher than originally intended... hence why it has 505hp, instead of the even 500hp the old system would have netted them. The Saturn Ion, and Chevy Cobalt also got a HP bump as well, from 140hp to 145hp. The Soltice and Sky also got bumped 7hp, if you compare the new and old literature, you'll see at first it was rated 170hp, but then later got re-rated at 177hp.
I googled it and found this:
http://www.detnews.com/2005/autosins...A01-283759.htm
Good article explaining what is going on with this newer, more accurate, testing.
Old Oct 17, 2006 | 09:23 AM
EVO Neil's Avatar
Correct - but they were overrating them from the factory.
Old Oct 17, 2006 | 09:41 AM
EVO Neil's Avatar
http://www.motortrend.com/roadtests/...yno/index.html
These are dyno runs for Evo VIII RS, GSR, and MR
http://www.motortrend.com/roadtests/.../photo_15.html
This one shows a dyno test between the Evo VIII MR and the WRX STi
Old Oct 17, 2006 | 02:07 PM
STISTL's Avatar
Boost controller and no engine managment that's why there were so slow. With those mods the car pulls timing like crazy. But hey a win is a win .
