335i Vishnu
Old Mar 24, 2007 | 03:01 PM
TeamTurtle's Avatar
335i Vishnu
While running through the Vishnu website, I came across this: http://www.vishnutuning.com/bmw_zero.htm
The point of interest is: "Through precise and methodical calibration with the Vishnu PROcede computer, we are able to extract another 55-60whp and 70-80lbft of torque. These monstrous gains are achieved with only two more pounds of boost from the clever factory twin turbo set up."
Discuss.
Old Mar 24, 2007 | 03:02 PM
scorke's Avatar
Well see when you turn up boost and change ignition timing and fueling values you increase the power output of turbocharged cars dramatically.
Scorke
Old Mar 24, 2007 | 03:08 PM
TVA's Avatar
TVA
335i's are supposedly detuned from the factory so they don't trounce the new M3 when it comes out. So far they've been making great gains across the board with just tuning.
Old Mar 24, 2007 | 03:13 PM
scorke's Avatar
Every car is detuned from the factory.
Scorke
Old Mar 24, 2007 | 03:20 PM
matyb's Avatar
the n54 is an awsome motor, has an awsome fuel sys. and duel VANOS
not being a ***** but those gains dont suprise me, im shure it was hard to pull off those results but those are only conservative. i promise shiv can get more outa that little b!tch!
Old Mar 24, 2007 | 03:21 PM
NoTec's Avatar
Scorke
Correct. And the 335's respond to tuning like the B5 S4's. Imagine if those B5's were a couple hundred lbs lighter and rear wheel drive.
Old Mar 24, 2007 | 03:33 PM
scorke's Avatar
Not quite like the B5 S4's, they made 380whp off of a flash.
The new RS4 will be just fine in my opinion NoTec 420bhp and a much more rearwardly biased 4wd system, the weight however you cannot remove from german "sports" cars.
Scorke
Old Mar 24, 2007 | 03:47 PM
blackonblackevo's Avatar
Scorke
That's crazy just with a flash.
Old Mar 24, 2007 | 03:50 PM
JTB's Avatar
JTB
I wish they had put this engine in the M version of the Z4. I am not sure if I would still be driving an Evo if they had
Old Mar 24, 2007 | 04:10 PM
bluebyu36's Avatar
i though tthey did have a m version of the z4
Old Mar 24, 2007 | 04:14 PM
matyb's Avatar
that car is already a tire smoker w/ the measly torque #'s of the s54 if they had put and n54 (the 335 motor) in it would have been crazy and it would be faster than the current e46 m3 (wich there are still a couple on the lots) and cost alot!!! it wouldnt make those owners too happy. also that engine is not badged as an M or "s" motor therefore it can not go in an "M" car. that engine may end up in an "e85" z4 chasis if the new m3 v8 ends up in there also, then it can be badged as the new z4 si
Old Mar 24, 2007 | 04:17 PM
m4tt VIII's Avatar
i wouldn't even get the new m3, a tuned 335i is gunna smoke it, plus i can get it in a sedan which is huge cuz i dont' like 2 dr cars. check out this weeks autoweek there is an article on vishnu's tuning of the evo ix and 335i
Old Mar 24, 2007 | 04:23 PM
matyb's Avatar
they do just not a version with the 335 motor.... like stated above ^^^
Old Mar 24, 2007 | 04:24 PM
TeamTurtle's Avatar
^^Most people don't get BMWs do "smoke" others.
Besides, the makeup of a M3 is much different from the twin turbo 335i.
Old Mar 24, 2007 | 04:30 PM
matyb's Avatar
were you talking about me with the "smoke" quote??? if so i think you
mis-understood.
as for the make up of an m3 being different from a 335i your right, the 335i is better
nevermind i see what you were talking about....
