Off Topic: 1992 Acura Integra Won't Crank
Old Dec 16, 2008 | 04:13 PM
bboy_RES's Avatar
i know this is an Evo forum, but maybe you guys can still help me fix my girlfriends car. she has a 1992 Acura Integra LS 1.8L. a couple days ago her car stopped cranking. i turn the key to the on position and the lights on the dash light up, the radio turns on (i recently put my subs/amp/speakers in her car), and her headlights work, but when i try to start the car it doesnt crank or anything. she had this problem 2 weeks ago and i thought my system might've killed her battery so after replacing it with a new one the car started fine. then it happened again a couple days ago so i charged her battery and it still didnt wanna crank. i thought it was the starter so i just replaced it a couple hours ago and it still doesnt wanna crank. i checked all her fuses and they look fine. i havent tested the starter lead wire yet, but that's next on my list after i finish this tuna sandwich. anyone have any other ideas?
Old Dec 16, 2008 | 04:20 PM
Tnnrx7's Avatar
Alternator.
Old Dec 16, 2008 | 04:30 PM
bboy_RES's Avatar
wouldn't the car still be able to be jumped even if the alternator was bad?
Old Dec 16, 2008 | 04:49 PM
Tnnrx7's Avatar
I had this problem in one of my old cars when I had subs, don't have them in the Evo.
This was a while back, but I'm pretty sure after we put in a new alternator that fixed the problem.
Could be a bad battery as well even if it's new; might want to have it checked.
Old Dec 16, 2008 | 05:01 PM
bboy_RES's Avatar
yeah i was actually gonna go to autozone to check the old starter and the battery as well. maybe the alternator got messed up after i put the subs in the car.
Old Dec 16, 2008 | 05:10 PM
tripperfx3's Avatar
You've got your 3 potential suspects there. The alternator, battery, or starter. I guessing you could probably count out the starter though since you just put a system in the car it probably fried the old alternator or battery.
Old Dec 16, 2008 | 06:38 PM
bboy_RES's Avatar
so the starter and the battery turned out to be fine. im gonna get the alternator checked right now. hopefully this is the problem.
Old Dec 16, 2008 | 06:40 PM
MuslimEvoFreak's Avatar
Not if you have a dead battery.
Old Dec 16, 2008 | 06:42 PM
0E3vobutt3r's Avatar
kinda had the same prob with my girls car, and I replaced the plugs and wires, worked for a while then did it again. Got a batt. and it worked for a while, then it happened again.
turned out to be a bad ground, check all your grounds could save you alot of time and money.
GL
Old Dec 16, 2008 | 07:06 PM
NVmySKILS's Avatar
From: across the river from the city that never sleeps
had the same prob long time ago...... my money is on the alternator
Old Dec 16, 2008 | 07:39 PM
baylorar's Avatar
+1. I had my subs in my grand am (many years ago, I was in high school ) and it fried the alternator within a day or two after having the subs put in
Racco
Nov 16, 2020 07:27 PM
EvolutionIXMR06
Mar 24, 2014 11:40 AM
evocivicmarc88
Jan 1, 2012 08:25 PM
nytalonTSi
Dec 15, 2010 06:32 PM
Evoryder
11
May 1, 2008 05:53 PM
