Car won't start, No crank or ignition...
Old Jan 10, 2012 | 05:13 PM
Racco's Avatar
My car was running fine, I parked at work in the morning and later tried turning it on and nothing. No crank. it was just as if you were trying to start your car without stepping on the clutch, nothing happens.
I got my battery tested and they said i needed a new one, so i replaced it but ut's still doing the same thing. There's no ignition, no crank, but lights come on in the interior.
Is it the starter? I checked my fuses under the hood and it's all good.
Any suggestions would be appreciated.
Thanks
Old Jan 10, 2012 | 09:01 PM
ChanseEvo8's Avatar
Registered User
check your ignition switch. As for the starter just jump a wire from the positive battery terminal to your starter B+ terminal to see if it crank. That will eliminate your starter if its the problem. You can also do a voltage drop, and use a test light to see if your switch is getting 12v.
Old Jan 11, 2012 | 09:34 AM
Racco's Avatar
I'll try that, but my battery gauge is on 12v when I switch the ignition. It drops to 0 volts when I attempt to start it. I wonder if all the juice is going to the starter?
Old Jan 11, 2012 | 01:46 PM
hiner005's Avatar
it isnt your starter...it will still try to crank if it is your starter. I would check the igniton switch for sure.
Old Jan 11, 2012 | 03:32 PM
AJCaron12's Avatar
When you re-connected the battery are the terminals tight enough so that they cannot be wiggled at all?
Old Jan 13, 2012 | 07:47 AM
Racco's Avatar
I actually went under the car and banged the crap out of the starter and it turned on. I would've never guess it was the starter
I'll be getting it replaced, thanks for all the help!
Old Feb 1, 2012 | 04:30 AM
MyEvo8Urs's Avatar
How did we go from sticker discussion to a no start diag in this thread?
Old Jun 13, 2012 | 03:37 PM
Allabouttrees's Avatar
Hi I have an Evo 8 mr with the manufactures alarm and a Clifford black jack I think today after it had ent been driven for a few weeks my battery went flat I got in as normal the car turned over but not fast anought to star so I went to jump start it but once connected I didn't have any ignition lights Theres defnatly power there just was wondering if it's the alarm playing up or something else many thanks dan
Old Nov 16, 2020 | 07:27 PM
Dre03's Avatar
My 2011 Mitsubishi Lancer gts won’t turn on
So I have a 2011 Mitsubishi Lancer gts & everything starts the lights inside but my headlights outside don’t turn on & the car doesn’t turn on either. It starts but nothing I put a new battery on it also.
Mackman
Apr 19, 2017 08:04 PM
KJS
Oct 4, 2016 06:58 AM
wwcagedevo8
11
Aug 4, 2014 06:03 PM
Tagge
10
Dec 23, 2012 05:20 PM
crossingfinger
Feb 24, 2010 09:47 PM
