IS300 - 4g63 swap build
I will start from the beginning. My name is Jusitn, and I own an IS300 that is currently getting a 4g63 engine. I am performing 99% of the work since I am the head technician at a performance shop in Atlanta GA (Batlground Motorsports). The engine setup is an evo 8 block mated to a 2g dsm head. The engine is getting a 100mm crank, eagle rods, and ross 9:1 pistons. The head is getting evo 8 valves, and BC valves and retainers. The cams have not been purchased yet. Turbo is a garrett 35r, and the car will be powered on e85 via an AEM EMS. The manifolds have not been made yet. Also I do not have a transmission, but that is going to be a t56 out of an ls1 camaro. The bellhousing will be made by bill hincher, but he has not released one for the evo block yet. The car will be used 90% on track, but it will remain tagged and insured, for weekend drives. The body kit is a wald with 1" flares. I might be going wider, as well as possibly a chopped top. I am going to do some track testing with a friends ls1 IS300 to see if wider will be needed. Currently it fits 18x9.5 +25 on all corners, with 265 series tires. After this event I will know if I want to go wider or not. Brakes and suspension will be done after all the fabrication f
or the engine is completed. Also the entire car will be painted during this ordeal. Here are the pics:
Back when she was stockish
Doing the flares
old beat up bodykit
pulling the 2jz
She had a twin, the white one now has an ls1
Doing the flares
old beat up bodykit
pulling the 2jz
Engine bay got emptied
mounted abs and electronic powersteering pump
started stitch welding
random parts i have for the build
cut the end tanks off so I can make more v-mount friendly ones
test fitted a bad evo block
I didnt like how far forward it sat, so I did some more cutting (more to come, I want the entire engine at least 1" behind the stock front subframe)
Interior, or lack there of
Did some more cutting
more parts, including a new body kit, minus flares, plus drysump parts
my car's twin, but running
(yes it is getting real headers/exhaust)
facing #1 cyl the evo exhaust manifold is on the right, while the dsm puts it on the left. The blocks are virtually the same, except mainly the bellhousing bolt pattern. There is also the fact that the dsm blocks like to crankwalk. My reasoning for this setup is to have all the turbo stuff on the opposite side of the steering column for ease of fitment, and the not crankwalk prone block. If you were to swap heads like this in an evo, the exhaust would be on the firewall, and the intake would be near the radiator.
While I'm a big fan of the 4g63, (as well as a lot of work I see come from Batlground I might add), I'm a little surprised to see you ditched the factory 2J, considering how easy it is to make power on it. Still, looking forward to watching the progress on this.
Started making the dry sump pan. It is approx 1/4" thick aluminum.
this section took a few hours to get the curves just right to match the curves of the front cover
I am not the worlds best welder, by a long shot, but not too bad.
The slope is to catch the oil as the crankshaft naturally slings it that way. There will be 2 big fittings on the larger side that go into the dry sump pump, as well as 1 more pickup on the valve cover.
The flat part is for clearance against the steering rack, that is an example of how far back I pan on putting the engine
Finished welding the outside.
yes, it is only 2.5" at it's highest point
and the inside, but not welded yet
That is where I am at now, feel free to tell me what you guys think, the good and bad. As well as what you guys think I should do, I do not know everything, and am up to suggestions.
Thank you for the kind words. The reason for ditching the 2jz is weight. It is near impossible to shove a 2jz that far back, plus it is just super heavy.
no its not, what makes the evo 4g63 more powerful is the head and the parts used for it. Evo head flows a lot more than the DSM head, bigger ports and some parts of the valve train are made from a special material to keep the mass down and durabile. You might want to do some more researching before putting this engine together. Yes a bare block is the same but internals and everything else is not.
That would blow up. I am using a 6speed from a 1997-2002 Camaro with a v8.
